Author Topic: 798 SI HD temp issues  (Read 11012 times)
Offline nitronut38
  • Quit Wishin' Go Fishin'
    • Get Reeled
  • Unit(s): 997c SI, 798C HD SI
« on: May 16, 2011, 09:57:23 AM »
Hope someone out there can help me out....
Just bought a new 798 HD SI. I have it on the front of my boat with the trolling motor transducer. I cannot seem to get a temperature reading in the water or even out of the water. My 997 at the console reads both in and out of the water. Did I hook something up wrong? Or is the issue with the software or maybe the transducer? Please help!
Quit
Offline FuzzyGrub
    • Joe Fish
  • Software: Latest
  • Accessories: TSW,
Re: 798 SI HD temp issues
« Reply #1 on: May 16, 2011, 10:11:25 AM »
Does the diagnostic screen show it as connected?  I believe temp is shown seperate than transducer on that screen.   If it does, maybe it is just not set-up/configured for the display.  If it doesn't, check to see if you have a bent or broken pin in connector.   Also, look for a pinched cable.
JohnS
http://joefishin.com/
« Reply #2 on: May 16, 2011, 04:00:17 PM »
nitronut38,
Which model transducer is this?
Offline nitronut38
    • Get Reeled
« Reply #3 on: May 16, 2011, 09:33:51 PM »
Doesn't seem to be anything that looks broken. Anything to the naked eye at least. The model of my transducer is XTM 9 SI 180 T.
Quit
« Reply #4 on: May 17, 2011, 12:48:09 PM »
That transducer has the built-in temperature sensor so the 798ci HD Si unit should read and display it.  Try connecting your 997 to the same transducer and see if you get a temperature reading.  That will let you know if it is the temperature sensor in the transducer that is bad or something with your 798ci HD Si unit.
by fishinphil
Last post February 04, 2012, 02:48:19 PM
Last post May 01, 2012, 12:52:17 PM
by xSilmarilSx
Last post May 22, 2015, 01:17:41 PM
Last post August 11, 2015, 09:19:37 AM
Last post August 30, 2019, 12:43:39 AM
Last post December 18, 2020, 10:28:00 PM
