Author Topic: Rooster Tail  (Read 24574 times)
Offline BaitCaster
  • Unit(s): 798ci si
Rooster Tail
« on: April 15, 2011, 10:08:04 AM »
So, took the boat out for the first outing since installing the fish finder.  My transducer throws a pretty bog rooster tail at WOT.  Is this normal/expected?  Anything I should do about it?
Offline jjbch
Re: Rooster Tail
« Reply #1 on: April 15, 2011, 10:36:06 PM »
I'm new to this as well, but I have read numerous posts about a plug that is suppose to eliminate that.  There are also post from people that have used other methods to solve that problem.  I think that Hummingbird has the plug.   There is a wealth of information on this site and quite a few guys that really know their stuff.
Offline BaitCaster
  • Unit(s): 798ci si
Re: Rooster Tail
« Reply #2 on: April 17, 2011, 12:23:41 PM »
Thanks for that.  I found the plug and installed it.  We'll see how it works.
Offline Curt - RI
  • Fish On!
    • Lure Parts
  • Unit(s): 788 CI, 798 CI HD SI
  • Software: 5.400, 5.410
Re: Rooster Tail
« Reply #3 on: April 28, 2011, 08:08:57 PM »
Can you explain what kind of plug you're referring to? Typically, a rooster tail is the result of a transducer being too low in the water when the boat is on plane. Or that's the way I've always understood it anyway.
Offline FuzzyGrub
    • Joe Fish
  • Software: Latest
  • Accessories: TSW,
Re: Rooster Tail
« Reply #4 on: April 28, 2011, 10:38:16 PM »
It goes between the arms on the mount.  From your earlier pictures, it looks like yours is installed.
JohnS
http://joefishin.com/
Offline BaitCaster
  • Unit(s): 798ci si
Re: Rooster Tail
« Reply #5 on: April 29, 2011, 10:01:34 AM »
This is what the pug looks like.  I installed it on my transducer (luckily I didn't throw it out thinking it was just a spare part).  Taking the boat out tomorrow and will see how it works.
Offline BaitCaster
  • Unit(s): 798ci si
Re: Rooster Tail
« Reply #6 on: May 02, 2011, 11:08:36 AM »
Problem solved.  The plug completely eliminated the rooster tail.
Offline clsmith1
  • Unit(s): 798
Re: Rooster Tail
« Reply #7 on: May 20, 2011, 02:23:21 PM »
How does this plug keep you from  spraying  a rooster tail  when  your transducer is mounted  below  the bottom of the boat?  whre is the best place to mount the transducer on a alum.  boat?
Offline edwardpic
  • Just fish....No excuses
    • My Company
  • Unit(s): 898c and 1198c
  • Software: 5.500 and 5.500
Re: Rooster Tail
« Reply #8 on: May 20, 2011, 03:19:46 PM »
where did you get the plug? directly from HB?
Big E
Offline Roddy
  • Scan,scan and rescan
Re: Rooster Tail
« Reply #9 on: May 20, 2011, 05:21:58 PM »
Edward: The plug stops the water from passing between the xducer wire and the mount. It plugs the space. Roddy
Scan,Scan and Rescan Roddy
Offline Roddy
Re: Rooster Tail
« Reply #10 on: May 21, 2011, 12:04:36 AM »
Edward; If the plug was not part of the kit call Humminbird to order the part. it just snaps in.  :) Roddy
Offline Phiznat5000
    • Gilman Fishing
  • Unit(s): Piranah Max, 798ci
  • Software: Most Recent
Re: Rooster Tail
« Reply #11 on: June 22, 2011, 02:25:43 PM »
LOL! Hey man I made the SAME mistake! I forgot to install the plug as well. Full speed in my boat and it was shooting water probably a good 15ft in the air. Its always the little things.
Go get em!
Last post April 30, 2011, 09:22:30 AM
Last post May 20, 2011, 05:28:46 PM
by Roddy
Last post July 08, 2014, 10:52:19 AM
by MTBob
Last post March 23, 2014, 01:56:00 AM
Last post October 13, 2014, 10:26:07 PM
by xSilmarilSx
Last post April 20, 2016, 10:04:42 PM
Last post September 02, 2016, 08:45:33 AM
Last post May 08, 2017, 08:34:39 PM
by fshndude
