Author Topic: New to Forums and Side Imaging  (Read 7944 times)
Offline jjbch
« on: March 24, 2011, 07:52:57 AM »
Have never been involved in a forum, so this is all new to me.
I am going to purchase a 797ci and have questions about performance when running boat at high speeds.
Does this unit read bottom at all with transom mounted transducer, or do I have to purchase another to read.  I understand that side imaging only works when going at slow speeds.  Sorry if this is not the place for this post. Thanks for the consideration.
Re: New to Forums and Side Imaging
« Reply #1 on: March 24, 2011, 08:41:30 AM »
Welcome to the forum.
Since you're new, maybe nobody told you.
It costs a million dollars to join up here, and that will be equally distrubuted amongst the current members.
Cash only please. :)  Just joking.
This is what I've learned about it:
With a tranducer on the transom, it is limited to speed because 1) The boat tends to lift up when on plane, and 2) There will be lots of turbulance at the transom and air bubbles formed.  Lots of air bubbles are created near the surface, which is where your transducer will be when you're on plane. Sonars don't like air bubbles.  They need solid water to work at their best.  Some people have had to move their transducers lower, but there is a limit to how low they can go because they could hit something.  If you're transducer hits something, in all likelyhood, you won't get any readings at any speed. :)
Some people mount a shoot through the hull puck on the inside of the boat, and this gives them the depth reading at any speed (0 through hauling ass).
It depends on what kind of boat you have if this will work or not (aluminum, versus wood, versus fiberglass).
I think side-imaging is limited to about 10 miles per hour.
There have been many posts about the speed issue and transducer mounting.  Use the forums Search feature to find them.
Good Luck.
« Last Edit: March 24, 2011, 08:45:37 AM by ITGEEK »
Offline jjbch
« Reply #2 on: March 24, 2011, 08:49:10 AM »
Thanks for the response. I am replacing a older lowrance, but maybe I should leave that for running and add the other. for the other purposes.
Thanks again.
Last post June 07, 2009, 06:50:55 PM
by Wylezalek
Last post June 08, 2015, 08:08:39 PM
by Bubba Canuck
Last post October 26, 2015, 09:34:42 PM
Last post July 19, 2017, 12:27:05 AM
Last post May 12, 2025, 05:38:26 AM
by Kenai
