Author Topic: Things needed to get started?  (Read 15900 times)
Offline tommyboyrn
  • Unit(s): 777C2, 998
  • Accessories: WeatherSense
« on: March 18, 2011, 11:21:25 PM »
I am thinking of getting a new 898 SI HD unit as an upgrade from my current 777c2. My questions are: 1. can I place transducer on my trolling motor? 2. What extra's will I need ( map card/ SD card and what size memory is best)? 3. Will a new unit come out of box with newest software or will i have to go online and upgrade software? 4.  Are the settingd fairly easy to "tweek"?
thanks for all info
Tom
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: Things needed to get started?
« Reply #1 on: March 19, 2011, 11:45:31 AM »
1-yes 2-map card of the area you are most likely going to fish,SD card  Sand Disk extremeIII 8gig 30mb/sec is what i use.3-unit may not  have the newest update when you register your unit on line  the newest update will be in your account .4- The HB'S are very easy to use and set between this forum and the BBC forum and HB
support you have all the resource you need to learn how to use your equipment. Gary
Offline tommyboyrn
« Reply #2 on: March 19, 2011, 09:38:16 PM »
Thanks, I appreciate your time and response.
Tom
Offline stillbear
  • Stillbear
« Reply #3 on: March 19, 2011, 11:11:52 PM »
Tom I put my 1198 on my TM I ordred a tranducer shield an saver mount from Scap
here is the address.  Gary        http://www.transducershieldandsaver.com
Offline tommyboyrn
« Reply #4 on: March 20, 2011, 04:48:47 PM »
those look really good! thanks for the hint. ;)
Offline tommyboyrn
« Reply #5 on: March 21, 2011, 11:36:58 AM »
The specs listed in the other thread showed the peak power to be 4000 watts peak to peak, but I looked on universalmania.com and basspro magizine, the same unit specs show peak to peak power to be 8000 watts.
What gives? And can anyone explain this concept?
Tom
Offline LoonASea
  • Unit(s): 898
« Reply #6 on: March 21, 2011, 05:32:28 PM »
I believe to get 8000 watts you need a different transducer then what comes with your unit...It should say something in the manuals you can download from HB
LAS
I married my wife for her looks,,,,Just not the looks she's giving me lately
Offline tommyboyrn
« Reply #7 on: March 24, 2011, 11:35:55 PM »
is there a place to go to help interpret the images. I mean, the dark column is under boat equal to the depth? the lighter colors on sides, what area in water column is that representing?
I know this may seem elementary, but just wanna get a basic grasp at what im seeing before I dive in.
Tom
« Reply #8 on: March 26, 2011, 12:50:14 AM »
Tommy,
Image interpretation is very important with Side Imaging.  I would recommend that you browse the image gallery and snapshots forum.  If you would like, post some images or ask about ones here on the forum and we can help.
Offline Moose1am
  • Unit(s): 898c si
  • Software: 6.610
« Reply #9 on: March 26, 2011, 09:41:37 PM »
The dark area in the center is the water column under your boat and it's the past history going from top to bottom on the screen.
The wider the water column shown the deeper the water.  If you go across a deep river channel you will see the dark area widen which represents the deep water channel of the river and then it will narrow again as you come up on the shelf.   Hope that answers your question.
With the new units and the newe firmware updates you can disable the water column and only show the bottom in SI mode.  And you can also add distance lines to both sides of the SI display.  That way you know approx how far away an object is by comparing the object to the distance lines on the display view in SI mode.
Tom
Regards,
Moose1am
Offline tommyboyrn
« Reply #10 on: March 26, 2011, 11:03:33 PM »
Thanks moose. I appreciate your time and info. I have not yet purchased a unit, but I AM GONNA HAVE TO THIS IS WAY COOL
Last post April 12, 2010, 08:12:23 AM
Last post July 16, 2010, 08:23:18 AM
by jtd123
Last post May 09, 2012, 03:06:12 PM
Last post September 20, 2013, 01:29:05 AM
by slabbacks
Last post April 30, 2014, 03:53:02 PM
by cdroke72
Last post November 17, 2014, 08:36:16 PM
by MT-ED
Last post March 12, 2015, 10:28:39 AM
by BrazosRiverTom
Last post September 22, 2019, 09:58:55 PM
