Author Topic: pls get me started  (Read 6855 times)
Offline jtd123
  • Unit(s): 997csi
  • Software: ?
pls get me started
« on: July 15, 2010, 08:35:48 PM »
i just bought a century 2202 bay and it came with a 997csi.  it has 2 transducers? a round shoot thru the hull and a flat transom mount. i am assuming one is for side imaging and the other down? is that correct? can i run both at same time on split screen?
Re: pls get me started
« Reply #1 on: July 15, 2010, 09:04:02 PM »
jtd123,
Welcome to the forum.  Yes, the flat one on the transom is for Side Imaging.  If there is a switch, you will have SI and depth (2d) from the transom and will be able to switch to the in-hull for better 2d depth reading at high speeds.
Most likely, you have an SIDB Y cable installed that will take the SI from the transom transducer and the 2d depth from the in-hull.  This is the prefered method so you dont have to worry about switching between the two.
You will be able to show them side by side with Y cable.
What else can we help with to get you started?
Offline jtd123
  • Unit(s): 997csi
  • Software: ?
« Reply #2 on: July 16, 2010, 03:08:05 AM »
thanks for the reply and no i am not usually up at 3am! how do i verify the y cable? if i dont have the y what would that mean to me? also pls am i suppose to down load any updates i read something about this machine and new down scan? thanks again
« Reply #3 on: July 16, 2010, 03:20:18 AM »
If you don't have a switch then you have the Y cable.  You can look on the back of the unit where the cable collector is and see if you see two transdcuer cables coming in.
As for updating the unit, if you do not have the Down Imaging installed, you will need to register the unit with Humminbird.com.  Then you will be able to download the lates updates under My Account.  We also have the updates here on the forum in the Downloads Section on the top menu.
Here is a link showing how to update your unit.
http://forums.sideimagingsoft.com/index.php?topic=14.0
Good luck,
Offline jtd123
  • Unit(s): 997csi
  • Software: ?
« Reply #4 on: July 16, 2010, 08:23:18 AM »
very good! the boat is in the shop getting a 1/2 tower put on. when i get it back i will look at it and do the downloads. thanks
Last post July 19, 2009, 01:00:00 PM
by Blackwaterkatz
Last post April 12, 2010, 08:12:23 AM
Last post December 14, 2010, 10:22:52 AM
Last post March 26, 2011, 11:03:33 PM
by tommyboyrn
Last post September 20, 2013, 01:29:05 AM
by slabbacks
Last post November 17, 2014, 08:36:16 PM
by MT-ED
Last post March 12, 2015, 10:28:39 AM
by BrazosRiverTom
