Author Topic: Transducer location help  (Read 9170 times)
Offline stuklose
  • Unit(s): 798c
« on: November 10, 2010, 11:41:23 PM »
I have just replaced my Himminbird 717 with a 798c. I placed the new transducer where the old one was located and went for a run. The 717 worked fine upto 20knots.
On the 798 the 2d sonar dropped out once i got on the plane at 13knots. I would get not pictur3e and measurement between 1 ft and 500ft. I then assumed it was too high.
I have since dropped the transuder down 10mm and will give it a run on the weekend.
Can someone have a look at my current setup and give me some feedback please.ila_renderedila_rendered
Offline stuklose
  • Unit(s): 798c
Re: Transducer location help
« Reply #1 on: November 10, 2010, 11:43:06 PM »
More picsila_renderedila_rendered
Offline stuklose
  • Unit(s): 798c
« Reply #2 on: November 10, 2010, 11:44:29 PM »
A side scan recording in 7-10ft of water.
« Reply #3 on: November 11, 2010, 09:59:31 AM »
stuklose,
If your 717 read the bottom at up to 20 knots than your new 798 should be able to do the same thing.  All you have to do is work at getting the transducer ride height and angle just right.  If lowering it does not help enough than try angling the back end down a degree or two and see if that helps.
Last post April 15, 2013, 03:05:31 PM
Last post April 15, 2013, 04:21:07 PM
Last post March 25, 2016, 05:56:45 PM
by fishreed
Last post April 06, 2016, 08:43:34 AM
by jabsy
Last post April 04, 2016, 10:15:28 PM
Last post February 04, 2017, 02:34:58 PM
Last post May 14, 2017, 11:15:29 AM
by Dieago
Last post May 03, 2017, 08:47:39 AM
