Author Topic: Jerry rigging AS-GR50 GPS to older units?  (Read 7265 times)
Offline kucai
  • Unit(s): Wide100, 737
« on: August 10, 2010, 01:32:14 AM »
Has anyone ever done it?
I understand that power requirement for the GPS is higher than older HB units can support, but can we connect the GPS directly to battery with in-line fuse? I read through the NMEA diy cable article and saw the red (power?) cable in the GPS pig tail, which makes me wonder if this is the power supply to the unit.
On another note. Does the GPS puck supply NMEA data to the head unit? I thought the signal would be in some raw format (rockwell whatever.. I think) direct to the head unit rather than NMEA.
Looking forward to your informed input.
Re: Jerry rigging AS-GR50 GPS to older units?
« Reply #1 on: August 23, 2010, 04:09:02 PM »
Yes in theory a GR50 could be rigged to work with one of the older units.  You would have to supply power on the correct wire and it should work.  I believe that you can use the Red wire that is on the pigtail for this.  Just remember to fuse it (the GPS Receiver does not pull that much current so even a 1 amp fuse will be too big for it).
The GPS Receiver sends NMEA 0183 data to the unit.
Last post August 25, 2010, 06:51:31 PM
by Jim_C
Last post March 14, 2012, 11:15:55 PM
by nhealy
Last post April 20, 2013, 12:32:29 PM
by LocDown
Last post April 25, 2013, 03:16:16 AM
by MarioFisherman
Last post April 06, 2015, 11:07:33 AM
Last post May 01, 2015, 11:32:39 PM
by dogridgekraus
Last post January 23, 2017, 01:52:04 PM
by Mark Saikaley
Last post November 30, 2017, 12:15:07 PM
by Diesel Pro
