Author Topic: fish id question  (Read 12501 times)
Offline riven1950
  • Unit(s): 798ci si
fish id question
« on: May 26, 2010, 09:52:09 AM »
I have used my 798cisi unit only 2-3 times and think it is great. I was in the ocean over a reef last week (40+/- depth ) and I could see what I think were fish on the sonar and we were catching fish....but the unit did not identify any fish on the screen. I did turn the fish id on through the menu....or at least thought I did. Am I missing something? Do I need to adjust sensitivity? How small of a fish will the unit identify?
Still learning...
Thanks,
Ted
Re: fish id question
« Reply #1 on: May 26, 2010, 04:12:50 PM »
Attach a picture (snapshot)  of your question. It is easier to answer if we can see what you are looking at also.
Offline riven1950
  • Unit(s): 798ci si
« Reply #2 on: May 26, 2010, 05:22:01 PM »
I will take snapshot asap. In the meantime one more question.
When the unit id's a fish is the fish shown as a symbol on the screen ( like a fish shape ) or do they just show up as blimps of various sizes?
Thanks,
Ted
Offline soretoe
« Reply #3 on: May 26, 2010, 06:06:09 PM »
Thanks,
Ted
Fish ID will show up as a fish. Any large object suspended in the water will also show up as a fish. I prefer to use mine with fish ID off. Run your unit in split screen where it uses side imiging. The4n you will know if you are seeing fish.
Freedom isnt free, if you want to know the real cost visit a national cemetery or VA Hospital.
I can also be found at;
http://allatoonabass.proboards.com/
Offline kucai
  • Unit(s): Wide100, 737
« Reply #4 on: June 11, 2010, 02:42:41 AM »
I think HB did one step better, it showed both fish symbols and the return signal (the inverted vees). With that you can basically decide for yourself whether the return signal could qualify as fish or not.
There was also an article from a guide (if I'm not mistaken) on how to setup the fish ID if you are going to use it. It focussed on crappie fishing, but the concept of why he used fish ID is very good despite the overall concensus of fishermen to turn fish ID off.
Not really the exact article, but similar to what I have on my hard drive:
 http://www.familyfishingtrips.com/News.htm#Getting%20the%20Most%20from%20your%20Sonar
Offline AZfisherdude
  • Unit(s): 798ci si
« Reply #5 on: June 24, 2010, 05:37:36 PM »
I'd be interested in reading the other article. Would you mind uploading it somewhere? That one you linked to was helpful too.
Wayne P.
  • Guest
« Reply #6 on: June 27, 2010, 11:52:19 AM »
This is what the Fish ID will show. I had the DI set to narrow view to attempt to match the 200 khz cone.  Didn't catch any fish indicated.
Offline kucai
« Reply #7 on: July 07, 2010, 04:47:41 AM »
Sorry for the late reply. File converted to ASCII text. Hopefuly it is of some use. I had only use my 737 once, so I can't comment much. So much work, so little time to fish.. :'(
  • Unit(s): 798ci si
« Reply #8 on: July 16, 2010, 03:00:07 AM »
Thanks, and thanks for the link as well. Hopefully I can start figuring out how to use this thing to actually identify fish.
Offline kucai
« Reply #9 on: October 13, 2010, 03:22:18 AM »
Another use for fish id that I found. Somewhat eliminate the need to split screen 83/200 Hz.
http://www.bbcboards.net/zerothread?id=589549
Last post June 24, 2009, 08:04:22 AM
by Jolly Roger
Last post July 08, 2009, 12:52:24 PM
Last post March 03, 2014, 07:47:25 PM
by slabbacks
Last post November 12, 2010, 09:51:51 AM
by Phiznat5000
Last post April 22, 2010, 09:33:45 AM
Last post July 16, 2010, 09:57:55 PM
by RzorbackAngler
Last post August 03, 2012, 10:59:32 AM
by ITGEEK
Last post November 09, 2017, 08:32:56 PM
