Author Topic: flush mounting  (Read 6597 times)
Offline stuart
  • Unit(s): 798 ci si
flush mounting
« on: May 23, 2010, 09:59:02 PM »
i want to flush mount my 798 ci SI in the dash .will it be ok if i get the gps puck? the flush mount kit says not recomended for internal gps units .also is the xp 9 20 the right thru hull transducer to use,i don't see 798 si listed with the xp 9 20 when i went to order it
Re: flush mounting
« Reply #1 on: May 23, 2010, 10:35:41 PM »
Stuart,
It should be fine flush mounted with the external GPS receiver.  Its not recommended if you are using the Internal receiver since it may interfere with the signal acquisition.
The xp-9-20 will work fine.
Good Luck,
Last post September 29, 2009, 07:58:28 AM
Last post April 25, 2010, 04:29:18 PM
by Kickerfish641
Last post April 26, 2010, 02:44:06 PM
Last post July 31, 2010, 08:06:51 PM
Last post January 10, 2011, 05:02:12 PM
by gobio
Last post December 20, 2010, 10:11:06 AM
Last post July 02, 2012, 05:02:07 PM
Last post July 03, 2013, 12:48:11 PM
