Author Topic: 998si & 9hdsi - Depth not working at plane  (Read 9536 times)
Offline sbrown
  • Unit(s): 989SI 597C
« on: May 22, 2010, 09:46:24 PM »
My unit's depth quits working once I get above 8MPH. I have a thru hull transducer on a 2008 Ranger boat. The mount is located on the bottom center of the hull well in front of the motor. any ideas?
Offline eric3338
  • Unit(s): 998c si nvb ,797c2 SI nvb
  • Software: 4.880, 4.770
  • Accessories: interlink weather sence
Re: 998si & 9hdsi - Depth not working at plane
« Reply #1 on: May 22, 2010, 10:13:42 PM »
when your boat is on plain most of the hull is out of water.transducer won't read though air.  Run your boat past a freind on a dock and check the location of the transducer.   You can also create a void in the water as it goes around the transducer. Hate to think you got in the wrong lacation.   :-[
Offline sbrown
« Reply #2 on: May 22, 2010, 10:52:51 PM »
My boat: '08 Ranger 188 VS had 2 factory installed X135 Lowrance units. Ranger put the temp probe thru the hull at the rear and the transducer was mounted inside the hull.
I "assumed" the temp probe hole would be the best place to put the SI transducer. It works well for the SI and temp, just no depth past 8MPH. It is a raised step area of the hull and it is possible that on plane it's out of the water.  If so, I  have two choices : Move the ransducer.....ouch or live with it and install a separate in-dash depth guage that  can shoot from inside the hull. Of course, this all assumes I am shooting air with my current set up.
Offline wizzo86
  • diving in phillapenes
« Reply #3 on: May 23, 2010, 11:21:38 AM »
I'm sure your out of the water or so much bubble turbulance that the ducer can not read.... You can look up similar problems people have had with your modle boat on the search option on this sight.... Just put your boat modle in the search and see it you can find it that way.... Good luck
Offline sbrown
« Reply #4 on: May 23, 2010, 09:20:15 PM »
I saw this posting from another Ranger owner who was having issues with his transdcer mounted on the step of his boat. Here is Greg's response:
Howie,
I would buy an AS-Si-DB-Y cable and XP-9-20 transducer and mount the transducer inside-the-hull in the bilge area of your boat.  This will be the best location on your boat (and any fiberglass planning type hull) in order to get a high-speed depth reading.  Leave the HDSi transducer where it is so it is somewhat protected and you get good Si sonar readings as well.
Report to moderator    Logged
I wonder if Greg's suggested cable set up would work with my current transducer??
Last post August 18, 2010, 04:08:12 PM
Last post June 05, 2011, 01:05:58 PM
by edwardpic
Last post April 08, 2013, 05:34:49 PM
by wolfs4evr
Last post February 24, 2013, 07:54:54 PM
by G4bama
Last post January 28, 2014, 02:44:30 PM
Last post June 29, 2015, 01:24:58 PM
Last post June 20, 2015, 02:25:23 PM
Last post February 29, 2016, 12:41:46 PM
by Spd 135
