Author Topic: 999ci - why mount transducer above plane  (Read 11485 times)
Offline aucivil
  • Unit(s): 999ci SI Combo
  • Accessories: I-Pilot Link - Minn Kota Ulterra
« on: June 19, 2015, 10:40:32 PM »
I read a lot about mounting the XHS 9 HDSI 180 T traducer above the at-speed plane line and mounting an additional shoot-thru transducer for at-speed readings.  The transducer has sonar capabilities so why not just mount it where it can be used for at-speed sonar and low-speed imaging?
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: 999ci - why mount transducer above plane
« Reply #1 on: June 20, 2015, 07:51:15 AM »
2 main reasons. To protect the expensive HDSI transducer and get better high speed readings. The large transducer is hard to get adjusted for 40 plus mph. I have done it with mine and it works up to 50 mph. I have an aluminum boat so I could not use an in hull. Bob
Offline aucivil
« Reply #2 on: June 20, 2015, 09:54:18 AM »
I'm having trouble with installing a shoot-through-hull transducer.  Very limited access to bilge area (unless you have monkey arms).  My cruising speed is 40mph or less.  My test location (board and C-clamp) worked at higher speed for depth.
« Reply #3 on: June 20, 2015, 02:25:23 PM »
It is entirely your choice if you use the stock XHS 9 HDSI 180 T for depth at high speed ...
Bob covered the possible reasons not to ... Expensive to replace the XHS 9 HDSI 180 T and difficulty in finding clean bubble free water coming off the back of the transom ...
Last post June 05, 2011, 01:05:58 PM
by edwardpic
by Brian37075
Last post February 24, 2013, 07:54:54 PM
by G4bama
Last post January 28, 2014, 02:44:30 PM
Last post May 28, 2014, 08:20:10 AM
Last post February 14, 2015, 12:21:31 PM
by BrokeLoser
Last post November 06, 2015, 05:55:18 AM
by skeeter08
Last post February 14, 2022, 11:21:22 PM
