Author Topic: whats wrong?  (Read 11721 times)
Offline JeffA
  • Unit(s): 898c SI
  • Software: 4.880
whats wrong?
« on: May 16, 2010, 09:20:54 PM »
this is all i can get for a reading with the 2d on my 898, i have y-cable with the 2d in the hull, mounted JUST like in the instructions said to, and the settings per-Humminbird at salt water deep and clutter at 9...this unit is going back, i plan on calling them tomorrow.
 "if your going to mess with the kings queens, you better watch your ace, jack!"..
Offline calli1
  • Unit(s): 1198 S I & 787c2i
Re: whats wrong?
« Reply #1 on: May 16, 2010, 10:25:48 PM »
Yes...you need to call them.  I looks almost like you are using the unit out of the water.  I will be willing to say that it is not your unit but in your transducer or cables.  Good Luck and the folks at cust. service will get you taken care of.
Re: whats wrong?
« Reply #2 on: May 18, 2010, 12:20:56 PM »
How deep was the water you were in when you made that screen snapshot Jeff?
The unit is showing a water depth of 21.9 feet deep but you have set the Lower Range menu to show only from zero to 10 feet deep (look in the lower right hand corner at the “M” by the lower range number “10”) or is it that the unit is not displaying a bottom reading?  If that is the problem than set the Lower Range menu back to the "Auto" setting.
Offline JeffA
  • Unit(s): 898c SI
  • Software: 4.880
Re: whats wrong?
« Reply #3 on: May 18, 2010, 07:06:02 PM »
i did notice that, i have no idea how it changed to M, but i changed it back, didnt help at all, pretty sure its either the Y-cable or the 2D, because it was fine after i unhooked the 2D.
Re: whats wrong?
« Reply #4 on: May 18, 2010, 09:06:08 PM »
Jeff,
You did change the depth lower limit back to auto?  Please post a screen shot with these changes adjusted.
Basically in the images you posted, you are only zoomed in on the top 10' of the water column so the bottom is not showing.  You could also try setting the lower limit
Thanks,
Offline JeffA
  • Unit(s): 898c SI
  • Software: 4.880
Re: whats wrong?
« Reply #5 on: May 19, 2010, 02:43:28 PM »
not even sure how it got switched ot "M" but i put it back to auto and it still looks just like that screen shot...i sent it back to Humminbird to have it looked at, they said i should send it in, for that and the shallow water issues..
Offline Takman74
  • Unit(s): 898cSI & 798CI HD DI
  • Accessories: Ethernet
Re: whats wrong?
« Reply #6 on: June 07, 2010, 10:49:18 PM »
Hey There
Can anyone explain what that 73deg/53deg line is at the top of the screen? I looked all over in my online manual and can't seem to find the answer. thanks,
Tom
Offline Louis
  • Unit(s): 1197c SI
  • Software: 4.750
  • Accessories: Weathersense
Re: whats wrong?
« Reply #7 on: June 08, 2010, 07:43:07 AM »
That is a water temperature line, 73 / 53 are the upper and lower limits. These will change as the water temp changes. I don't know why they have such a wide variable , but the line in the middle will go up and down as the water temp changes.
Last post July 14, 2010, 03:29:39 AM
by johno r
Last post March 21, 2011, 07:41:22 PM
Last post July 02, 2011, 05:10:34 PM
Last post July 22, 2011, 01:14:49 AM
by muskyhunter
Last post October 06, 2014, 12:41:12 AM
Last post January 18, 2015, 06:43:36 PM
by dan8965
Last post June 01, 2016, 08:46:10 AM
Last post June 02, 2016, 11:09:04 AM
