Author Topic: transducer selection?  (Read 7071 times)
Offline bearpeter1
  • Unit(s): 998 SI
  • Software: latest
  • Accessories: humviever
« on: May 05, 2010, 09:52:02 PM »
in 1 of the sub menu's there is the choose of side scan ,hi def side scan,duel ,etc etc. since it is a 998SI do I leave it on only one of the settings or can I use more than one.
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
Re: transducer selection?
« Reply #1 on: May 06, 2010, 06:54:09 AM »
Leave it on the default setting Peter.
If you would have one of the older SI transducers which work with 262 and 455 kHz you would be able to choose the Side Scan setting and use the 262 kHz. The 998 transducer is a HDSI (High Definition) transducer since it uses 455 kHz and 800kHz.
The 800 kHz gives you the best details on the screen, while the 455 kHz give you the better area coverage.
Regards / Harry
YES,......
WE SCAN!
by Sonshine Fishing
Last post April 16, 2010, 04:00:01 PM
by ETnSC
Last post May 22, 2012, 05:09:01 PM
Last post June 05, 2011, 06:04:09 PM
Last post March 29, 2012, 10:08:32 AM
Last post August 06, 2012, 03:19:17 PM
by lajo1976
Last post June 16, 2014, 04:39:58 PM
Last post March 20, 2016, 07:41:08 PM
