Author Topic: 2 pictures of bridges I found  (Read 11018 times)
Offline jimf
  • Unit(s): 997ci si
« on: April 16, 2010, 09:07:05 PM »
1 bridge is very good shape, lake was filled 1970's. you can see creek under the bridge and the humps along side of the road.
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
Re: 2 pictures of bridges I found
« Reply #1 on: April 17, 2010, 06:12:00 PM »
Excellent shots jimf!!!
I really like the forst one for its clarity, beautiful!
Regards / Harry
YES,......
WE SCAN!
Offline jimf
  • Unit(s): 997ci si
« Reply #2 on: April 17, 2010, 10:30:33 PM »
thanks
I came to find out that if you go and scan the side of the bridge you get a better shot of it then if you went from the other way around.
I had the sensity on auto and chart speed at 4. 3 was a little slow and 5 was to fast.
I still haveing some problem with the 2 D sonar. I wrote to post about ti but know one wrote back yet.
 IF the red on the bottom is thick dos that mean its a hard or soft bottom ?
Because I was setting on big rock near the bank and my bottom reading was light blue and yellow BUT had a small second reading unuder it and it was little red spots.
So I really don't know what color rocks (hard bottom) should look like on the screen
JIM
Offline Jolly Roger
  • HB Addicted
« Reply #3 on: April 18, 2010, 03:32:19 AM »
Jim,
I'm not familiar with the newer models, but I assume a red bottom signal indicates a hard bottom like with my good old 981.
Regards / Harry
« Last Edit: April 18, 2010, 08:41:46 AM by Jolly Roger »
YES,......
WE SCAN!
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #4 on: April 18, 2010, 07:41:41 AM »
Jimf very good shots. When you get a second echo the bottom is hard red means high
intensity return. red ,yellow,green,blue,whiteline highlights the strongest sonar return.Soft bottoms usually don't have second returns.    Gary
« Last Edit: April 18, 2010, 08:55:10 AM by stillbear »
Last post April 25, 2012, 03:36:17 PM
Last post January 17, 2013, 12:11:30 PM
Last post May 16, 2013, 09:15:37 PM
by Rotus623
Last post November 07, 2013, 01:07:44 PM
by matt@reefmaster
Last post March 18, 2014, 06:57:13 AM
by slabbacks
Last post January 03, 2015, 08:01:31 PM
Last post November 25, 2015, 11:01:36 AM
by kosmo
Last post December 08, 2017, 03:06:22 PM
by Deckedoutjonboats
