Author Topic: Low voltage issues  (Read 11370 times)
Offline JWN
  • Unit(s): 898
Low voltage issues
« on: September 18, 2024, 05:11:06 PM »
So, I have a Helix 10 which is from when they first came out. Everything works great still except it continually shuts down due to low voltage. I traced the voltage from the battery through fuse box ect, and have high 12 to low 13's right up to the head unit. The power port male side has good voltage but when plugged into the head unit the head unit only read 10V or less usually, on a rare occurrence    I may see a 11v reading but rare. I have cleaned all connections and no change. Anyone have a solution to this issue?
Re: Low voltage issues
« Reply #1 on: September 18, 2024, 07:55:43 PM »
Have you tried Restore Defaults ??
Offline JWN
  • Unit(s): 898
« Reply #2 on: September 19, 2024, 06:24:21 AM »
I have not but I will asap and see if that helps. Thanks
by fishinphil
Low Voltage
Started by spes 798c SI
Last post January 27, 2013, 03:23:36 PM
by strawdg
Last post April 09, 2013, 10:40:21 AM
by jepik
Last post March 24, 2014, 03:13:28 PM
Last post August 12, 2014, 12:30:15 PM
Last post March 09, 2019, 10:29:45 PM
by hollada
Last post September 20, 2019, 07:39:35 PM
by G48
