Author Topic: Helix and 1199 compatibility  (Read 16269 times)
Offline bigmoe
  • Unit(s): 898si
« on: March 10, 2024, 01:41:33 PM »
I’m moving on from my 1199 to a new helix 12 si G4 and I have a few questions on compatibility.
1. Is the in hull transducer I have installed XP9 20 t compatible or is there a better transducer?
2. Will my Navionics card and my SD stored waypoints card plug in without issues?
3. Is the Y cable I have installed for the 1199 be compatibleP?
Re: Helix and 1199 compatibility
« Reply #1 on: March 10, 2024, 08:22:49 PM »
1. No  ... HELIX 12 CHIRP MSI+ G4N uses HW CHIRP low Q 2d and your current in hull transducer is 83/200kHz 2d  ... you will need the XP 9 HW in hull transducer  ... https://humminbird.johnsonoutdoors.com/us/shop/accessories/transducers/xp-9-hw-helix-dual-spectrum-chirp-hull-transducer
2. Yes  ...
3. No  ... AS SIDBY Cable is not compatible with HELIX G3N or G4N units  ... you will need the 9 M SIDB Y cable which also has a dedicated DI circuit  ... https://humminbird.johnsonoutdoors.com/us/shop/accessories/cables/9-m-sidb-y-helix-side-imaging-2d-sonar-splitter-cable
« Last Edit: March 10, 2024, 08:27:02 PM by rnvinc »
Offline bigmoe
  • Unit(s): 898si
« Reply #2 on: March 11, 2024, 12:00:57 PM »
Ricki thanks for the response now all I need to do is pull the plug on the new one.
Do you have a sales pitch for me? I’m easily persuaded if the technology of the Helix G4 far far far exceeds the old 1199 si.
« Reply #3 on: March 11, 2024, 07:37:57 PM »
Better SI
Better DI
Better 2d
Compatible with MEGA 360
Compatible with MEGA Live
Compatible with LakeMaster VX mapping
Shares all Sonar with your current HELIX
Last post March 04, 2016, 07:01:07 PM
Last post February 14, 2017, 10:05:14 PM
by Bergy1
Last post August 16, 2017, 09:22:03 PM
Last post March 25, 2019, 02:01:28 PM
by RivRunR
Last post April 24, 2019, 09:13:25 PM
Last post October 25, 2019, 12:11:39 PM
by ezfishn
Last post November 21, 2019, 05:35:54 PM
by KJINTF
Last post September 05, 2022, 09:36:15 PM
by skipt
