Author Topic: Solix not recording Mega 360  (Read 14476 times)
Offline Jopple
  • Unit(s): Solix 15
  • Accessories: Mega360
« on: September 16, 2022, 09:45:29 AM »
Hi all,
Having an issue with my Solix and Mega 360 in that it won't record the 360.
Solix 15 MSI+ G3 Software Version 4.0.70.(06/09/22 19:23)
Mega 360 Imaging V1.070
The 360 works fine, and recording SI is no problem but if I try to record just 360, the "start recording" button does nothing and just stays there. If I select SI and 360 it appears to start recording but then reviewing the recorded files, there is no 360 data.
Anyone got any ideas?
Offline oschi
  • Unit(s): HELIX 9 CHIRP MEGA SI+ GPS G4, MEGA Live
  • Software: 2.800
Re: Solix not recording Mega 360
« Reply #1 on: September 16, 2022, 01:59:20 PM »
Send me your recordings with at least one full 360 turn. I'll look into it and if the angle value is stored in the files I would implement a 360 view in HummSucker.
Offline Jopple
  • Unit(s): Solix 15
« Reply #2 on: September 16, 2022, 02:06:59 PM »
Hi,
There isn't a recording to send to you. That's the problem.
It only records when in SI or DI mode - it's not recording any 360 data. In the recordings list there is no indicator in the 360 column.
If I try to record a 360 file only, the recording never starts at all.
Offline oschi
  • Software: 2.800
« Reply #3 on: September 16, 2022, 03:14:09 PM »
It should be possible.
Found this
http://www.bbcboards.net/showthread.php?t=425537&p=4144982&viewfull=1#post4144982
It's only SI but maybe the angles are saved in the xxx2 and xxx3 son files.
Could you record SI if using 360?
« Reply #4 on: September 16, 2022, 08:54:13 PM »
Offline oschi
  • Software: 2.800
« Reply #5 on: October 11, 2022, 07:53:31 AM »
Does it work now?
Offline Jopple
  • Unit(s): Solix 15
« Reply #6 on: October 11, 2022, 10:55:56 AM »
No, it has been  raised with Humminbird support who are checking to see if there is a firmware issue. It's been about 2 weeks so far. Once I get an answer/solution I will post back here with the resolution.
Offline Jopple
  • Unit(s): Solix 15
« Reply #7 on: June 24, 2023, 07:59:10 AM »
Just to keep things rolling -
Current release for the Solix is   - SOLIX G3 Series v. 4.130 Released February 9, 2023 which does not work.
Humminbird has acknowledged there is a problem and will be fixing it in the next firmware release, hopefully soon!
Offline Jopple
  • Unit(s): Solix 15
« Reply #8 on: November 06, 2023, 04:18:32 PM »
The new firmware for the SOLIX has been released:-
SOLIX (all models)     4.190
Released October 5, 2023
I have tested this and can now confirm the 360 scans are now being recorded.
Last post August 30, 2017, 09:10:38 PM
by fshndude
Last post December 29, 2017, 11:23:06 AM
by bigkahuna
Last post March 05, 2019, 08:30:40 AM
Last post May 02, 2019, 12:26:32 PM
by abraquelebout
Last post July 25, 2021, 10:24:57 AM
by danlaboucane
Last post July 25, 2021, 02:38:37 AM
by Rüdiger
Last post October 18, 2021, 09:34:16 PM
Last post October 25, 2022, 09:18:31 PM
