Author Topic: Helix 7 MSI GPS G4N  (Read 7954 times)
Offline John Coward
  • Unit(s): Helix 7 MSI GPS G4N
  • Software: 2.660
Helix 7 MSI GPS G4N
« on: May 10, 2022, 03:28:03 AM »
Hi. Does anyone have the newest Helix 7 MSI GPS G4N. If so, could you tell if your unit has the side and down image view together. Humminbird technical are telling me they have removed this view from this unit and replaced it with SI/SI view instead.
Humminbird told me to reset my unit back to factory settings, and then put it in advance mode, make sure the correct transducer was selected and try again, and when I had done all these things and took a video of me doing this and sent it to them, they then tell me my unit does not have this view.
I'm left wondering if they are fobbing me off.
Best wishes
John.
Offline Randysbird
  • Unit(s): 1
  • Software: 2.780
  • Accessories: Mega live
Re: Helix 7 MSI GPS G4N
« Reply #1 on: July 11, 2024, 11:53:55 PM »
Yes it does
Works great
Offline Kenai
    • Confidence
  • Unit(s): 598, Helix MSI+ 9 G4N, Helix 7 CHIRP G3N
  • Software: v7.300, v2.930
« Reply #2 on: July 13, 2024, 09:01:13 PM »
Best wishes
John.
Try to press and hold view button until it shows you a view express menu with possible views. Also, try to double-check if that view is not hidden under view tab in menu. Additionally, you can try in simulator. If there is a problem with the transfer, it will not occur in the simulator.
If that doesn't help, I would go to the nearest shop and try it on a different unit.
Last post February 19, 2018, 08:24:42 PM
by Whistler
Last post April 03, 2019, 11:27:28 AM
Last post March 14, 2020, 01:34:42 AM
Last post August 11, 2020, 11:12:55 PM
