Author Topic: Transducer not enabled  (Read 5276 times)
Offline Luke222
  • Unit(s): Solix 15 gen3
« on: April 17, 2022, 09:27:18 PM »
Hi,
I have a solix 15 GN3, worked fine until last trip. Once I turn the unit on, there is no depth reading. The only way to fix this is to put the unit in standby mode, and then out of standby and then it reads that transducer is enabled, and i get a read out. Any help would be appreciated.
Cheers
Re: Transducer not enabled
« Reply #1 on: April 17, 2022, 09:40:19 PM »
Well that’s an unusual gremlin  ...
From the Home screen select Restore Defaults  ...
Then in the right pane select Restore Sonar defaults  ... test the results  ...
If that doesn’t fix the issue try a full Restore Defaults on that same page  ...
Offline Luke222
« Reply #2 on: April 17, 2022, 10:32:12 PM »
No wuckers, will suss this out later. 🤞
by Sonshine Fishing
by Brian37075
by jgcox6
by bobcoy
Last post May 02, 2014, 08:09:36 PM
by bobcoy
Last post January 27, 2015, 10:32:43 PM
by Fredfx21
