Author Topic: 999ci - Is transducer going bad or something else  (Read 10107 times)
Offline FL_freshwater
  • Unit(s): 898ci and 999hd si
« on: February 13, 2022, 07:28:51 PM »
The last two times I have taken the boat out the down and side imaging just looks horrible. Even the normal sonar is useless. I have the latest updates installed. I watched tutorial videos and have tried every setting I can with no luck. Even when I tried to use the simulator it didn't look as bad as the attached pics but it didn't look as good as it once did a few months ago. The attached pics are with the transducer setting in a bucket of water at the house. The good pic is what it used to look like. Any thoughts or suggestions on what I should check?
Re: 999ci - Is transducer going bad or something else
« Reply #1 on: February 13, 2022, 07:30:42 PM »
More pics, messed up on the first post
« Reply #2 on: February 13, 2022, 09:48:20 PM »
Have you tried Restore Defaults  ... ??
« Reply #3 on: February 14, 2022, 06:44:27 AM »
I did try that. Those pics are after restoring and verifying I had latest software updates
« Reply #4 on: February 14, 2022, 11:21:22 PM »
The next troubleshooting step would be to try your head unit on another xducer - or another xducer on your head unit  ...
Last post May 28, 2014, 08:20:10 AM
Last post February 14, 2015, 12:21:31 PM
by BrokeLoser
Last post March 25, 2015, 02:13:54 PM
by mako9man2
Last post June 20, 2015, 02:25:23 PM
Last post November 06, 2015, 05:55:18 AM
by skeeter08
Last post June 27, 2016, 08:49:01 AM
Last post November 23, 2016, 10:30:11 PM
by rickmbp
Last post May 21, 2018, 09:46:24 PM
