Author Topic: Helix 7 MegaDI gen4  (Read 3353 times)
Offline Jw452
  • Unit(s): Helix7 Gen4 mega di/si
Helix 7 MegaDI gen4
« on: January 06, 2022, 11:25:49 AM »
My unit has two forward facing micro-SD slots.  Why, and what is the most efficient use for them?
Jw452
Re: Helix 7 MegaDI gen4
« Reply #1 on: January 06, 2022, 11:07:25 PM »
Most use one card slot for a mapping card which provides better detail than the built in mapping feature  ... Humminbird units can use LakeMaster or Navionics mapping card products  ...
Some use a second card slot for using a blank SD Card (32gb max) for capturing screenshots  ... (screenshots are written directly to a SD Card and not stored in a HELIX unit memory)  ...
Offline Jw452
« Reply #2 on: January 07, 2022, 09:46:46 AM »
Thank you for the reply. I知 still reading the 350 page manual, but I have yet to find answers.  I知 still wondering if it matters which slot is used for mapping discs, and which is for screenshots; Or will the unit give me a choice if I try to save a screenshot.  I知 sure more experience will teach me. Thanks, again
Jw452
« Reply #3 on: January 07, 2022, 10:23:51 PM »
I do know it doesn稚 matter which slot is used for a mapping card  ... the unit will recognize the mapping card  ...
I do know that if only a blank SD Card is inserted - screenshots will be saved to the blank SD Card  ...
I do know that units that have 2 full size SD Card slots - the mapping card itself has a slide lock that prevents writing screenshots to that mapping card  ...
I do know that micro SD Cards do not have a slide lock feature  ...
I知 not sure how the unit reacts with screenshots when a micro mapping card and a blank micro SD Card are inserted  ... I知 fairly certain one of the card slots is 電efault� in this scenario  ...
I will test and see if I can discern  ...
« Last Edit: January 07, 2022, 10:26:43 PM by rnvinc »
Offline Jw452
« Reply #4 on: January 08, 2022, 09:40:35 AM »
Thanks, Rickie.
Jw452
« Reply #5 on: January 09, 2022, 01:41:36 PM »
Here are the results of testing dual SD Card slots  ...
*Left card slot - map card  ... Right card slot - blank SD Card = ScreenShot goes to Left map card  ...
*Left card slot - blank SD Card  ... Right card slot - map card = ScreenShot goes to Left blank SD Card  ...
*Left card slot - empty  ... Right card slot - blank SD Card = ScreenShot goes to Right blank SD Card  ...
*Left card slot - blank SD Card  ... Right card slot empty = ScreenShot goes to Left blank SD Card  ...
Meaning = map card should go in the Right card slot to prevent ScreenShots from 殿ccidentally� being written to the map card  ...
覧-
Note - if one 殿ccidentally� writes a ScreenShot to an unlocked map card  ... simply open the SD Card in PC or Mac and DELETE the 鉄CREENSHOT� folder  ...
« Last Edit: January 09, 2022, 01:58:18 PM by rnvinc »
Last post April 03, 2019, 11:27:28 AM
Last post March 14, 2020, 01:34:42 AM
Last post April 15, 2020, 09:51:39 AM
by bglures
Last post August 11, 2020, 11:12:55 PM
