Author Topic: Pair of side imaging transducers for Helix  (Read 6675 times)
Offline stoporilshoot
  • Unit(s): 998c SI
« on: January 03, 2022, 02:50:01 PM »
Hi, I'm back enjoying being a boat owner again. My last boat was outboard powered and I had the pleasure of having a 998C SI unit, I got it around 2010, I think at the time it was only Humminbird doing the side imaging (I live in the UK and managed to get the unit from the USA bypassing the import duty etc)
The boat I have now is semi displacement with a diesel shaft drive, 3ft draught, deadrise of 15 deg. I'm going to rig it out with some new elctronics, a good chart plotter with side imaging is top of the list. I fish mainly very shallow salt water 10-40 ft. I'd like to go with Humminbird again, possibly a Helix 10 DI+SI. Would I be able to get a pair of through hull transducers that would give 100% functionality of the plotter.
 I can't really find much information on a pair of transducers except a pair it says that are compatible with: SOLIX 12 SI, SOLIX 15 SI, ONIX Series and ION Series.
Cheers and thanks for looking
« Last Edit: January 03, 2022, 02:51:51 PM by stoporilshoot »
Re: Pair of side imaging transducers for Helix
« Reply #1 on: January 03, 2022, 09:45:19 PM »
HELIX 10 CHIRP MEGA SI+ GPS G4N comes standard with the XM 9 HW MSI T transom mount xducer  ...
It is possible to purchase HELIX 10 CHIRP MEGA SI+ GPS G4N CHO (control head only)  ...
https://humminbird.johnsonoutdoors.com/fish-finders/helix/helix-10-chirp-mega-si-gps-g4n-cho
Then purchase separately 2 of the XPTH 9 HW MSI T “thru hull” xducers  ... (these requires drilling a hole thru the hull for mounting)  ...
https://humminbird.johnsonoutdoors.com/accessories/transducers/xpth-9-hw-msi-t-helix-mega-si-di-dual-spectrum-chirp-w-temp-plastic-thru?_ga=2.269060466.2047277185.1641263597-1607435902.1641263597
You would also need the 9 M SILR Y cables to split off the left SI to come from the port mounted thru hull xducer  ...
https://humminbird.johnsonoutdoors.com/accessories/cables/9-m-silr-y-helix-side-imaging-left-right-splitter-cable
CHIRP HW 2d, DI, right SI and temperature would still come from the starboard mounted thru hull xducer  ...
« Last Edit: January 03, 2022, 09:47:55 PM by rnvinc »
  • Unit(s): 998c SI
« Reply #2 on: January 04, 2022, 02:48:46 AM »
Rickie...That's great information. Many thanks!
Offline Rüdiger
« Reply #3 on: January 04, 2022, 04:34:30 AM »
Very Nice boat .
mvh
Rüdiger
Finding is better than losing
  • Unit(s): 998c SI
« Reply #4 on: January 04, 2022, 04:53:20 AM »
Thanks...it's going to need some cosmetic work etc but hopefully all will be good
« Reply #5 on: January 04, 2022, 10:49:10 PM »
Please share pix of your electronics install progress  ...
Many here follow in the background that could learn volumes from your experience  ...
Last post January 19, 2017, 11:13:58 PM
Last post March 21, 2017, 05:00:45 PM
Last post May 30, 2018, 08:11:04 AM
Last post June 19, 2019, 08:30:04 AM
by davidgronskei
Last post December 27, 2019, 09:19:44 AM
Last post September 07, 2020, 09:33:15 PM
Last post April 14, 2021, 11:00:26 PM
Last post May 04, 2022, 01:22:04 AM
by John Coward
