Author Topic: SI log does not show up in the recordings  (Read 13480 times)
Offline emerles
  • Unit(s): Helix 7 / Helix 10
  • Software: latest
  • Accessories: 360 Mega
« on: October 26, 2020, 12:37:53 PM »
I am using a Helix10 since some month.
In the frist months I was recording the sonar logs.
Autochart was showing the SI log perfectly.
Then I installed a Mega360 transducer.
After uninstalling the Mega360 (forget 360 and restore defaults) the SI information does not show up in Autochart anymore.
Is there a "stronger" reset necessary to get the SI information logged again?
Re: SI log does not show up in the recordings
« Reply #1 on: October 26, 2020, 09:53:35 PM »
If no one pops in with help in your question - Humminbird may be able to help  ...
https://www.humminbird.com/contact?_ga=2.90502362.1950770098.1603763516-149481921.1603593819
Offline emerles
  • Software: latest
« Reply #2 on: October 29, 2020, 03:58:06 AM »
The Humminbird support is not very helpful so far.
I told them that I have executed the menu points "forget M360" and restore defaults.
The recommendation of the Humminbird support was: that I shall execute the menu points "forget M360" and restore defaults.
Is there a possibility to force the sonar to reinstall the firmware again?
I guess this would reset everything.
Wolfgang
Offline oschi
  • Unit(s): HELIX 9 CHIRP MEGA SI+ GPS G4, MEGA Live
  • Software: 2.800
« Reply #3 on: October 29, 2020, 11:26:24 AM »
Tried already?
Restore System Defaults
Use the following instructions to reset ALL menu settings to the factory defaults.
CAUTION! Use this menu with caution!
1. Main Menu: Press the MENU key twice. Select the Setup tab.
2. Select Restore Defaults.
3. Press the RIGHT Cursor key.
4. Follow the on-screen prompts to confirm the reset.
Offline emerles
  • Software: latest
« Reply #4 on: October 29, 2020, 02:43:22 PM »
Yes - I restored the default factory settings - it did not work.
Thanks for the hint.
Best regards
Wolfgang
« Reply #5 on: October 29, 2020, 07:08:16 PM »
Wolfgang
It is not possible to install the same version of software that is already on the unit  ...
It is sometimes possible to backdate to a previous software version - and then update again to the newest software  ... (It is never recommended to backdate to a software version earlier than what came on the unit)  ...
Humminbird might send you a previous software version  ...
Offline emerles
  • Software: latest
« Reply #6 on: October 30, 2020, 04:46:54 AM »
This sounds good - even if it seems to be a bit risky.
I will contact the Humminbird support with that proposal.
Thanks for answering.
Wolfgang
Offline emerles
  • Software: latest
« Reply #7 on: November 01, 2020, 09:17:38 AM »
Just to let you know.
The Humminbird support told me, there is no older software version.
It is a bug in the current software version and there will be a fix in one of the future software releases.
Offline emerles
  • Software: latest
« Reply #8 on: June 14, 2021, 01:25:39 AM »
I have installed the latest update.
The bug is not corrected.
I am not using the 360 all the time.
Is there a possibility to reset the sonar to company defaults?
This would help for the time using the standard transducer.
I have read about holding down the on/off switch for 20 secs would perform a hard reset of the sonar.
Would this be a solution?
« Reply #9 on: June 14, 2021, 11:26:18 PM »
HB has never affirmed there is a “hard reset” procedure for HELIX units  ... and as far as I know no one has ever found one (if it exists)  ...
Restore Defaults does put the unit back to factory default settings but does not revert the original software that came on the unit  ...
Offline oschi
  • Software: 2.800
« Reply #10 on: June 15, 2021, 01:06:16 AM »
If you want you can send me your recordings. I can read and analyze them.
In the son files is a byte that identifies the beam (2D, SI left/right, DI).
I guess there is something wrong with autochart. Same problem with Humviewer.
Offline emerles
  • Software: latest
« Reply #11 on: June 16, 2021, 05:05:15 AM »
thanks alot for your offer, but I would like to reset the sonar to the factory default (see next post).
Offline emerles
  • Software: latest
« Reply #12 on: June 16, 2021, 05:11:34 AM »
Thanks Rickie for the quick reply.
I think that I have formulated my problem too misleading.
I bought my Helix10 and the 360 degree transducer last year.
Once I connected the 360 degree transducer, the logging of the SI data stopped working.
Now I have recently installed firmware version 2.180.
Although I did not have the 360 transducer connected, the firmware reported the 360 as connected.
I ran "forget 360" and "restore defaults".
Then the Helix recognized the standard transducer, but it did not execute the "restore defaults" command.
The logging of the SI-data of the plugged in standard transducer does not work either.
So my problem is that the command "restore defaults" is not executed.
Since I drive 90% of my time with the standard transducer, it would be enough for me if I could reset the Helix to factory settings.
Then maybe the logging of the SI data with the default transducer would also work again.
Is there another solution besides "restore defaults" to reset the Helix to factory settings?
« Last Edit: June 16, 2021, 05:13:03 AM by emerles »
« Reply #13 on: June 16, 2021, 10:40:38 PM »
You might contact HB again with your serial number handy and ask them what version of software came on that unit originally  ...
Then come here with new post asking if anyone would have that software version for your specific unit model  ...
Offline emerles
  • Software: latest
« Reply #14 on: June 17, 2021, 02:29:11 AM »
Thanks alot, Rickie.
I'm going to do it this way.
Offline emerles
  • Software: latest
« Reply #15 on: June 18, 2021, 07:57:58 AM »
Last year my Helix 10 had the version V2.180 installed.
I also got this firmware version downloaded now.
When I upgraded to V2.280 I also installed the new basemap.
When I now switch back to V2.180 may this produce a conflict or problem?
br
Wolfgang
« Last Edit: June 18, 2021, 08:03:54 AM by emerles »
« Reply #16 on: June 18, 2021, 10:53:51 PM »
br
Wolfgang
Humminbird actually rarely recommends backdating software but some have successfully to rectify problems  ...
The best scenario would be to get the unit back to Humminbird for repair  ... but that may not be feasible in your case  ...
It might be a good idea to contact Humminbird again and explain that you have updated firmware and basemap and what would be their recommendation on backdating to original software  ...
Last post May 29, 2009, 10:10:31 AM
Last post July 27, 2017, 12:16:41 AM
by JOHN CASTELLUCCIO
Last post May 17, 2014, 07:59:42 PM
Last post July 10, 2018, 01:35:12 PM
by Mark Saikaley
Last post December 10, 2016, 12:14:53 AM
Last post July 08, 2017, 12:00:00 AM
Last post July 24, 2017, 07:53:52 PM
by TnTaz
Last post July 18, 2024, 09:07:41 PM
