Author Topic: 999 doesn't show bottom above 10 mph  (Read 12549 times)
Offline brents89
  • Unit(s): 999
« on: December 04, 2016, 07:10:28 PM »
I have just bought a boat with the 999 ci HD SI unit installed. I noticed that when I would go over about 8 mph the unit would lose the bottom. I was told it needed a second transducer to work at higher speeds so I had one installed. It was a little better, but still lose bottom after about 10 mph. SI, DI and 2d all seem very good at trolling speeds up to approx. 5 mph, but then deteriorate as speed increases.  I was told the transducer may need to be adjusted, but any additional thoughts would be appreciated.
Re: 999 doesn't show bottom above 10 mph
« Reply #1 on: December 04, 2016, 08:43:37 PM »
What boat do you have .... pictures of the transom from various angle will help.
The transducer has to be located where it will have smooth water flow without bubbles .... sonar won't shoo thru the air in the bubbles.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #2 on: December 06, 2016, 02:42:14 PM »
Are you still viewing the SI or DI page at the higher speed when you lose bottom readings?   If so, switch to the 2D page and see if the bottom reading is still shown.  If the 2D isn't shown, a
transducer adjustment is needed. The SI and DI are not designed to work at high speeds and those speeds are about when you stop seeing the images.
           Mike
Offline brents89
  • Unit(s): 999
« Reply #3 on: December 06, 2016, 07:26:34 PM »
Sorry i didn't specify but the picture was taken with 2D on. I took another look at the transducer and believe that the back may need to be adjusted down one notch. As the snow is starting to fly, I think this won't get tested until next spring. Thanks for the replys.
« Reply #4 on: December 06, 2016, 11:43:43 PM »
A transom mount xducer should be mounted as indicated in the diagram below ...
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #5 on: December 10, 2016, 12:14:53 AM »
I would add that after leveling the bracket as in Rickie's illustration, I have found that my high speed images (2D) improve with the rear of the transducer slightly lower that the front edge.
         Mike
Last post May 29, 2009, 10:10:31 AM
Last post July 27, 2017, 12:16:41 AM
by JOHN CASTELLUCCIO
Last post January 07, 2014, 09:28:27 AM
by vik33
Last post May 17, 2014, 07:59:42 PM
Last post July 08, 2017, 12:00:00 AM
Last post July 24, 2017, 07:53:52 PM
by TnTaz
Last post October 10, 2019, 11:18:42 PM
Last post April 28, 2020, 03:54:03 PM
