Author Topic: Questions about G2 and G3?  (Read 4874 times)
Offline proskeeterman@comcast.net
  • Unit(s): 997c Nav Helix 7 Si G3
  • Software: 6.300
  • Accessories: None
« on: May 14, 2020, 01:59:20 PM »
Can someone give me the difference/s between a Helix/Solix G2 unit and a G3 unit? Is it only the
wattage output  from 4,000 to 8,000 watts? Also is there a way to upgrade a G2 unit and make it a G3?
Thank you.
Re: Questions about G2 and G3?
« Reply #1 on: May 14, 2020, 10:26:19 PM »
HELIX current is G3N  ...
SOLIX current is G2  ...
That’s simply because HELIX has been available longer in 3 generations  ...
HELIX G3N adds (over HELIX G2N)  ...
*Dual Spectrum Low Q CHIRP 2d
*MEGA+ DI/SI imaging with more range and detail from HELIX G2N MEGA imaging
SOLIX G2 adds (over SOLIX G1)  ...
*MEGA+ DI/SI imaging with more range and detail from SOLIX G1 imaging  ...
The Wattage output difference is entailed in the “+” part of MEGA+ more range  ...
It is not possible to “upgrade” a unit from an older generation into a newer generation  ...
« Last Edit: May 14, 2020, 10:27:49 PM by rnvinc »
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #2 on: May 16, 2020, 12:09:01 AM »
Rickie,
        Thanks for the expanded explanation.  I find it harder now to keep up with all the different units.   And, I've given up on trying to understand the price jump from 10" to 12" units.
        When you get in this price range, I'd like to get it right the first time.
              Mike
« Reply #3 on: May 16, 2020, 08:47:15 AM »
It is always challenging to keep up with all the changes and models  ...
  • Software: 6.300
  • Accessories: None
« Reply #4 on: May 16, 2020, 11:03:27 AM »
Rickie thanks alot, that helped a bunch.
Last post April 08, 2010, 02:51:31 PM
Last post May 09, 2010, 10:20:50 PM
by parole05
Last post February 18, 2011, 07:25:20 AM
by gofission
Last post November 08, 2011, 12:56:58 PM
Last post January 22, 2013, 04:16:17 AM
by Rüdiger
Last post August 10, 2014, 11:08:10 PM
Last post October 25, 2015, 09:11:53 PM
Last post May 13, 2015, 11:49:09 PM
