Author Topic: 2nd Damaged Si transducer wire. Any chance of repair  (Read 13631 times)
Offline Jw2000uk
« on: January 22, 2020, 11:24:00 AM »
Hi lads, this is the 2nd time this has happend.
So I'm £600 down :(
It's in salt water, cable has plenty of play.
But again, its corroded away in the same spot.
Is there anything I can do? The quality is so poor for this to happen.
Re: 2nd Damaged Si transducer wire. Any chance of repair
« Reply #1 on: January 22, 2020, 09:34:31 PM »
I have fair success with Goop Marine glue on the cable strain relief grommet to protect the grommet from wear  ...
https://www.amazon.com/Amazing-GOOP-170011-Marine-Adhesive/dp/B081XMZQPJ
It stays flexible even after curing  ...
I have never ventured into trying to repair wiring in the xducer housing  ...
« Last Edit: January 22, 2020, 09:35:57 PM by rnvinc »
Offline Jw2000uk
« Reply #2 on: January 23, 2020, 05:56:18 AM »
Cheers mate. That might come in handy all being well
Offline peterv6i
  • Unit(s): 998ci
  • Software: 4.500
  • Accessories: 998ci
« Reply #3 on: July 26, 2020, 11:09:59 AM »
Heh.. this is a poor quality product!
I have replaced two transducers in less than 8 years... The problem is that humidity and water enter (where gromet is) into the transducer and the galvanic current will "eat" the aluminium shield and you will get "snow" on the screen.. What I have done is that I have put a "plastic" tube over the cable and fixed and filled it with epoxy resin (tube cca 10cm in length). In this way, there is less possibility for the water to enter the transducer.  If you compare Humminbird transducer with Lowrance or Garmin you will notice the difference...
The green object represents the plastic tube.. I have fixed it with epoxy and filled it with epoxy.. You can also try to weld the plastic tube and then fill it with epoxy..
« Last Edit: July 26, 2020, 11:19:46 AM by peterv6i »
« Reply #4 on: July 26, 2020, 09:57:27 PM »
Good idea Peter  ...
I’ve often wonderEd if the rubber grommet is made from a rubber type that just doesn’t hold up to the elements  ...
I even use Goop Marine on my brand new xducers rubber grommet simply because I expect the rubber grommet to deteriorate over time  ...
Offline peterv6i
  • Unit(s): 998ci
  • Software: 4.500
« Reply #5 on: July 27, 2020, 01:45:00 AM »
the rubber grommet is not ok because there are almost two things:
1.) after a while the grommet will become "hard" and it will not seal..
2.) when you navigate with the boat at higher speed, a certain amount of force is working on a cable and grommet.
When humidity and water enter into the transducer the first thing which will go is the aluminium shield/foil which covers certain cables. Then you will notice interferences on the screen (white spots like it is snowing on the screen).  And I have tried to fix both transducers but no way to solve it..
Offline peterv6i
  • Unit(s): 998ci
  • Software: 4.500
« Reply #6 on: July 28, 2020, 01:38:38 AM »
Good idea Peter  ...
My friends have also tried Sikaflex and Kent but without success...
Last post September 08, 2011, 09:28:48 AM
by Jim Pauley
Last post October 18, 2011, 03:32:26 PM
Last post February 12, 2013, 02:16:48 PM
by Perch Jerker
Last post May 14, 2013, 08:47:28 PM
by 234rick
Last post September 02, 2015, 04:10:47 PM
Last post October 18, 2015, 09:21:29 PM
by larry crouch
Last post September 09, 2018, 07:58:26 AM
Last post August 05, 2024, 11:16:40 AM
by tournevase
