Author Topic: Transducer Compatibility  (Read 6655 times)
Offline ifishnc
  • Unit(s): Helix 5 SI GPS
« on: January 18, 2020, 09:36:49 AM »
I recently bought a Helix 7 SI G3. I had a Helix 5 SI on the console and moved it up to the front of the boat and put the new Helix 7 on the console. I had updated the transducer for the Helix 5 to improve SI. My question is, will the updated transducer for the Helix 5 work on the Helix 7?  If it does. I won't have to rewire the new 7.  Sorry I dont have the trasducer model # but I can get it if someone can help me.
Re: Transducer Compatibility
« Reply #1 on: January 18, 2020, 09:16:51 PM »
What is the model number of the upgraded xducer you used on the 5  ... ?? (It should have a tag close to the connector end)  ...
Then look in the Connected Transducer selection Menu under the Sonar tab in the HELIX 7 to see if that xducer is listed  ...
Offline ifishnc
« Reply #2 on: January 19, 2020, 11:31:26 AM »
Rickie, Thanks for the quick reply. The Helix 5 update model was XHS9HDSI180T. I couldn't find the 7 model where you said. It just gives me the choices to use.  No tag on ducer.  The best I can do now is to say it (Helix 7) is the standard ducer that came with model 410950-1 'bird.  I would have moved the XHS to the bow with the 5 but it is too big for my trolling motor so I used the original. If you need more info let me know and I will dig deeper.  Thanks again.
« Reply #3 on: January 19, 2020, 08:44:22 PM »
Look in the Helix 7 Connected Transducer selection Menu for “Hi Def Side Imaging”  ...
This selection will transmit 83kHz/200kHz for 2d and 455kHz for SI/DI  ... which is the frequency capabilities of the XHS 9 HDSI 180 T  ...
« Last Edit: January 19, 2020, 08:49:15 PM by rnvinc »
« Reply #4 on: January 19, 2020, 08:48:32 PM »
One thing to note is that the stock xducer (XM 9 HW MSI 150 T) that came with your HELIX 7 MEGA G3 has better 2d capability (and MEGA 1200kHz SI capability) than the XHS 9 HDSI 180 T  ...
« Last Edit: January 19, 2020, 08:50:43 PM by rnvinc »
Offline ifishnc
« Reply #5 on: January 20, 2020, 08:20:45 AM »
Based on that I decided to use the xducer that came with the 7.  Besides, I was having a lot of trouble with the other one reading at speed. Hopefully this one is better.  It is smaller. I did finally find the model # for the 7 in the manual - but who reads directions? Thanks so much for your input.
Last post March 06, 2014, 09:34:10 PM
by Catfish Capone
Last post September 16, 2014, 03:47:29 PM
by Bayou Basser
Last post July 21, 2015, 06:40:23 PM
by Spd 135
Last post January 17, 2017, 10:51:09 AM
Last post July 05, 2017, 09:34:54 PM
Last post August 16, 2017, 09:22:03 PM
Last post March 25, 2019, 02:01:28 PM
by RivRunR
Last post April 24, 2019, 09:13:25 PM
