Author Topic: will 360 transducer work without others transducers installed on a 998c si ?  (Read 15203 times)
Offline Carver
    • CNC carving and Pattern making
  • Unit(s): 398 and 998 si on kayaks
  • Software: 570
  • Accessories: weathersense
I have a 998c si head unit and want to temporarily put the ( original ) 360 transducer and head unit on a new boat for a short trip.   I'll probably be putting a full installation when I have the time but am not really wanting the side imaging right now.
Thanks in advance. Phill
Phill Pittman ---- Rogue Kayak Angler
Offline FishinLite
  • Software: 7.765
A Humminbird 360 is an Ethernet based transducer and it functions independent of any other transducers installed or not installed. It works fine with both of my networked Helix 9s at the same time.
I don't know  the 998c si, so my question is does it have a Ethernet port on the back.  If not you are out of luck.
Offline Carver
  • Software: 570
The connector from my 360 transducer is a circular 8 port connector.  There is separate power connector.  This is the first edition 350 transducer. I bought it when they were firdt released.   It does no look like what I think of as an ethernet connector.   I couldn't get through to humminbird support.
360 ethernet will connect to the metal connector in the center of the back panel of the xx8 series  ...
You may need latest software for that model (I'm not not sure)  ...
As FishInLite mentions  ... 360 will work without any other xducer (or the AS GPS HS antenna)  attached  ...
An added 2d xducer (in any HB xducer) allows displaying depth on the 360 image  ...
An added AS GPS HS antenna allows displaying waypoints on the 360 image  ...
« Last Edit: October 23, 2019, 10:14:01 PM by rnvinc »
Offline Carver
  • Software: 570
I went ahead and removed the components from my old yak and installed them on my new yak ( Oddly callled a Hobie "360" also ).
It appears it is going to work without installing the other transducers or gps.  I'll be bale to put it in water and confirm it is working by the end of the weekend.
Thanks, Phill
Offline ezfishn
Version 6.74 added the capability for 360.  So, you would need that update or later when using the 360.  The latest update for the 998 is version 7.67 software.  I have the update files for the 998c SI model if needed, let me know.
Last post February 11, 2010, 01:07:13 PM
by keizerh
Last post July 15, 2012, 08:33:37 AM
by ClemsonBloz
Last post October 22, 2012, 04:17:05 PM
Last post March 26, 2013, 04:15:52 AM
by Gator
Last post May 08, 2013, 11:51:13 AM
Last post December 30, 2013, 12:05:41 PM
by Rotus623
Last post December 06, 2016, 09:17:49 AM
by trogersIII
Last post February 25, 2020, 12:54:25 PM
by ezfishn
