Author Topic: Helix G3 and towfish  (Read 33814 times)
Offline abraquelebout
« on: May 02, 2019, 12:41:29 PM »
hi
Just a small news
I do a towfish with Hélix G3, for moment 50 m câble, first trial on 1 mai, all is OK, it work well, small noise at 400-500 on 455 chip but very good screen....200 m side by side are comming at 455 ??? new test is comming this week ....
Offline Rüdiger
Re: Helix G3 and towfish
« Reply #1 on: May 03, 2019, 04:30:59 AM »
Hi Felix
I'm looking forward to the first pictures, like comparable with older HB units.
Mvh
Rüdiger
Finding is better than losing
Offline sss_floripa
  • Unit(s): HELIX 10 CHIRP MEGA SI+ GPS G3N
  • Software: 2.110
  • Accessories: AutoChart Pro 2.300
« Reply #2 on: June 09, 2019, 08:28:45 AM »
hi
Just a small news
Hello, any update of Helix G3 with Towfish?
Thank you !
« Reply #3 on: June 10, 2019, 11:57:31 AM »
hi
some screen shoot with deepview 3, conversion in xtf do best view before reef upgrade....
in sea, 240 m coverage at 455 chirp, in river mega+ to view a future archéological area....1300 khz give some null effect at short range i prefer usine select
whe must test again to use the best of G3....but there's more detail at long range
Offline sss_floripa
  • Software: 2.110
« Reply #4 on: June 10, 2019, 12:23:19 PM »
Fantastic !!
What is the length of the cable (towfish) ?
Thank´s
« Reply #5 on: June 11, 2019, 01:03:35 PM »
Cable at 50 meters, for moment....may be 100 m in few weeks ;D
Offline Rüdiger
« Reply #6 on: June 12, 2019, 04:08:03 AM »
Hi Felix
That looks very good.
Thank you.
mvh
Rüdiger
Offline sss_floripa
  • Software: 2.110
« Reply #7 on: June 12, 2019, 12:17:36 PM »
Is the cable used the same as other posts (Cat 7a S/FTP) ?
Sorry for asking so many questions.
I'm going to set up my Tow Fish and I can not go wrong.
Thank you.
« Reply #8 on: June 14, 2019, 01:06:24 PM »
hi
yes, the cable is 7a sftp,the wiring i do is the same for méga G2.
Offline frankie_fin
  • Unit(s): helix 12 mega g3n
« Reply #9 on: September 08, 2019, 12:15:17 PM »
Hi guys,
Have you made any extra sealing for the transducer cable entry (picture helps) ? How deep your towfish are swimming?
« Reply #10 on: September 08, 2019, 12:23:39 PM »
Hi
No extra sealing for the cable entry, for moment max deep use with 100 m câble is 45 m, no problem, but it's true, the sealing seem's not strong.
Offline Chris_NSB
  • Unit(s): 798ci si and Helix 9 MEGA Gen 2
  • Software: latest
  • Accessories: Heading sensor & through hall transducer
« Reply #11 on: January 09, 2021, 10:38:13 PM »
I believe the transducer is potted in some type of resin. I had an older 798 that was stored in a hot garage and something that looked like resin oozed out of it. So I think it's likely safe at depth.
Also, I'm just finishing up building my own Helix 9 G2 DIY towfish. Let me know what you think:
« Reply #12 on: January 10, 2021, 04:46:47 AM »
hi chris
it seem's good
if you want to know what is in ducer there is repply in forum
http://forums.sideimagingsoft.com/index.php?topic=10052.0
Offline nan1
  • Unit(s): helix10 G4
« Reply #13 on: January 17, 2024, 06:05:43 PM »
Hi
What about the Helix G3 tests?
With 50 metres cable the résults in 455 chirp and 1300 are very Good. What about 800 hertz?
Have you similar résults with 80 m or 100 m cable?
Bravo et merci for sharing your researchs
Bernard
« Reply #14 on: January 20, 2024, 04:06:53 AM »
hi Bernard
now whe  use two towfishs with 80 m câble for deep water and one with 20 m for under 12 m depth
all frequencies give good result but whe can see a little lost signal in coverage distances.
this pics is with chirp at 1000 / 1300 in river made with 20m tow câble , it's an old wreek protected with bidim and sand bags
and this is 2 canons with the 80m câble towfish in salt water at 455 khz chirp
it's interesting ::::whe lost use  800khz chirp ....may be  a try in fiew weeks...
Offline nan1
« Reply #15 on: January 20, 2024, 04:17:29 PM »
Bonjour Felix,
Thanks a lot for your reply.
I am amazed by the quality of your results with un equipement costing around 2000 euros !
I think i'am going to build one myself, taking a lot of inspirations from yours.
Are you still using a 10 or 12 helix  G3 or have you switched to the G4?
Is the 80 mètres cable still  a Cat 7 A SFTP?
Why don't you keep the probe cable whole by interposing the Cat 7 cable in a 3 mètres extension cable cut in two? i suppose there would be a loss of signal?
The photos of the connexions show singles strand copper wires; why don't you use more flexible multibrins copper  ?
Thank you again for sharing your experience.
Bernard
Offline nan1
« Reply #16 on: January 20, 2024, 04:24:11 PM »
Sorry!!
I wrote in English and he he translated it into French!!
« Reply #17 on: January 21, 2024, 05:08:23 AM »
hi
Whe use an helix 9 G3, and a 12G4 , it works with same result.
the câble is a cat 7 A sftp  in simple Wire.
The attempts with flexible multibrins give us bad return and lost signals
I solder it and change cable every year or 1,5 year
some people make connection using underwater connectors but it's expensive
and sorry for my verry bad english
the thing i earn more in my studies is "Take the door" :D
Offline nan1
« Reply #18 on: January 22, 2024, 04:02:34 AM »
Hi Félix
Don't be sorry for your English, it's not worse than mine.  I write on this forum with the help of French English translation software which is also a little approximate.
In any case, thanks to this forum and in particular to you, i have now almost all the elements to get started. The sounder G3 ou G4, the cable and is maximum possible length, the connection to be established, and all possible fishes.
Just one last question if possible.
From your photos i have the impression that you shortened the probe cable a lot to connect with tha Cat 7. If so what what length of probe cable do you keep?
I had thought about keeping all the probe cable and using a 3-meter cut extension cable to interpose the Cat 7. Do you think this could cause signal loss? I will use an 80-meter cable.
Many thanks for your knowledge-sharing
Bernard
« Reply #19 on: January 22, 2024, 01:34:20 PM »
hi Bernard
I cut the ducer cable  at 1 m after probe, the cat 7 cable take the traction (1 m make me sure that i can cut and change the cable for many years)
i weld all wire and isolate them before making a waterproof finition.
keep us informed for your work and design ;)
Offline nan1
« Reply #20 on: January 22, 2024, 05:17:51 PM »
Thanks a lot Felix !
Now i have all the elements to get started.
I plan to explore the depths of the Mediterranean between 45 and 65 meters which will require significant ballast and above all very low progress to lower the ducer to around 45 meters; I hope to start in June and will not fail to report back to you.
Good luck for your researchs with the Arepmaref.
Bernard
Last post February 24, 2010, 05:11:58 PM
Last post November 23, 2013, 06:05:17 AM
by SSBN
Last post February 09, 2014, 12:19:12 PM
by MT-ED
Last post February 28, 2014, 04:37:18 AM
by Rüdiger
Last post September 08, 2019, 11:45:19 AM
by frankie_fin
Last post October 27, 2021, 08:19:06 PM
Last post March 30, 2023, 07:37:12 PM
