Author Topic: How to change out transducer plugged into a Y cable?  (Read 8573 times)
Offline Gdog
  • Unit(s): 998 CI HD; 597 C DI
« on: April 22, 2013, 10:58:50 PM »
I am having an issue with one side of my side imaging showing much darker than the other.  Humminbird said they would send me a new transducer but when I plugged the first one into the Y cable it took effort and snapped into place.  It seems to be locked in and I do not want to force it for fear of breaking the Y cable connector and then having to get a new one of those.  Is there a trick to getting these undone?
Re: How to change out transducer plugged into a Y cable?
« Reply #1 on: April 23, 2013, 10:57:48 AM »
Not trying to be a smart-butt here but: Get a good grip and pull!
I’ve had to use a pair of channel-lock pliers as my grip is not as good as it once was…
Offline Redge
  • Unit(s): 958, 1198
  • Software: 6.68, 6.74
  • Accessories: HS puck
« Reply #2 on: April 23, 2013, 07:05:53 PM »
It does take a lot more effort than a man would think!
« Reply #3 on: April 24, 2013, 10:53:57 AM »
As a friend of mine once said: “It’s a three grunter at least!”.
Offline Gdog
« Reply #4 on: April 28, 2013, 11:07:49 AM »
Thanks!  I got it - just wanted to make sure not to damage anything.
Offline ClemsonBloz
  • Unit(s): 798 si
« Reply #5 on: April 28, 2013, 02:10:19 PM »
Where can I find what part numbers that I need to purchase to install the extra sacrificial transducer??
I am tired of my SI ducer taking a beating when I take the boat into the swamp and want to mount it high under the outboard..
I can't really find any concrete part numbers for the ducer and y cable... I have the non Ethernet 798c SI
Any help would be super!
« Reply #6 on: April 29, 2013, 02:07:22 PM »
Are you talking about the 2D (DualBeam) transducer?
Where will this be mounted: on the transom or inside-the-hull (fiberglass hulled boats only)?
Offline ClemsonBloz
  • Unit(s): 798 si
« Reply #7 on: April 29, 2013, 09:17:46 PM »
I am looking to install an additional 2d ducer, correct. I have an aluminum boat, so any installation would have to be external..
thanks in advance!
« Reply #8 on: April 30, 2013, 03:46:39 PM »
That would have to be an XNT-9-20 transom mount DualBeam transducer and the AS-Si-DB-Y transducer splitter cable.
by Rickard
Last post April 09, 2012, 05:18:50 PM
Last post May 08, 2013, 03:09:46 AM
by basshunter.1
Last post January 05, 2014, 10:56:35 AM
by Dieago
by bobcoy
Last post May 23, 2014, 04:52:03 PM
by Arby2
Last post April 14, 2020, 08:31:19 AM
by Philip Brown
