Author Topic: 998 HD SI utomatic shut down and reload if only pwer cable is plugged in  (Read 7382 times)
Offline basshunter.1
  • pike is my dope , bass is my life
  • Unit(s): 998 1198 788DI
  • Software: 7.130 7.020
  • Accessories: 360SSI weather sense
Hi guys, i've update to vers 6610 my 998 Hd and at the beginnig it works fine for a couple of month , till i've started to record  images and datas from my 360SSI. Initially seems to works fine and record all info, till i've plugged it in to my computer for way points download and recordings analisis ( SD card only plugged in the computer for data anlisis  ) using Hummview...of course the 360 datas was funny to be viewed on this software that isn't already set for it ...it was just my curiosity....
then i've  reinsert the SD card in the unit ( without making any modification on it ) and i've powered  the unit  with an exsternal appropriate  power as i normally do...then when started in simulator mode......as i change any view the unit lock itself and reboot automatically without any exsternal imput......never done before....and do this at any view modification that i do
If i start the unit in normal mode ( no gps and ducer cable  installed ) due to temporally  down load instalaltion ( no USB cable connected ), the unit show only recording page, status page...no more....but if i try to play any of the 360 recording .......the unit  lock itself and then crash and reboot as before rappresented.....
why?????
now i'm curious to instal the 998  in the boat with all the ethernet cables connection,gps HRS, 360SSI....and see if it's working or is just an unpeasent bug pop up after the 6610 Srev installation......
Grag if you have any notice about this news......let me know.....here in Italy i'm waithing some good news......
sorry for my english.....but isn't my mother language!!! nobady is perfect!!
ciao
gianluca
Does it do any of these things without the SD card installed?
Hey, English isn’t my mother language either – I live in Alabama! LOL!
i'll try to do without SD card.....but yesterday i've tryed the unit on my boat, fully installed  and recording out of water 4 minutes of DI & SI combo view not the 360 images. Uniti works well, no auto reload or strange tings, pagese scroll fine....till...i've decided to see the file  just recorded ......HERE YOU ARE......may be 3 sec of play back and then te unit crash again......restart itself.......work fine at all  ....till you decide to replay the recorded file.....it crash at any time....Removed the Sd card and insert in the computer in Hummview ......recording file has no problem....so i dont' think that is a question of SD ( SD 10HD 4 GB ) but to get a fine trouble shooting , today i'll try a different SD and i'll see...... :-\ :-\ :-\  i'll let you informed saw that this is a common problem popping up.....
thanks GREG!!! ;D
Last post May 18, 2010, 06:56:27 PM
by Takman74
Last post June 27, 2010, 09:23:10 PM
by raricker
Last post December 01, 2011, 02:41:34 PM
Last post July 13, 2013, 06:51:56 AM
Last post September 11, 2012, 07:30:05 AM
by gros21
Last post November 27, 2012, 08:38:44 PM
Last post April 30, 2013, 03:46:39 PM
Last post August 09, 2013, 06:57:05 PM
by Jdeee
