Author Topic: Many Green Boxes  (Read 11870 times)
Offline Sawyer
  • Unit(s): 999ci HD SI
  • Software: v_7.020
Many Green Boxes
« on: May 30, 2018, 09:59:01 AM »
Being new to AutoChart I may be doing things wrong. Since importing, mapping & updating my AC card several times with recordings and tracks after different outings, I find I am getting lots of green boxes. When I "map here" i only show the information in a certain area of the lake, not the whole lake. I feel like I am only updating the card with a portion of the whole track or recording. I ask if I am doing wrong now, before I invest too much time removing bad data and importing more files. It seems like each time I import a file AC creates another box. Attached is a screenshot of the lake with the boxes. Any help will be appreciated.
« Last Edit: May 30, 2018, 02:07:26 PM by Sawyer »
New boat... rigging & learning.
Offline FishSeeker
  • Unit(s): Gen 1 Helix 12 Si & 10 SI
  • Software: 1.9
  • Accessories: Ulterra 80
Re: Many Green Boxes
« Reply #1 on: May 30, 2018, 11:30:29 PM »
There's an excellent tutorial on AC / AC Pro in another forum that should be very helpful to you, it certainly helped me.
In case you haven't already seen it;  http://forums.sideimagingsoft.com/index.php?topic=8122.0
I hope this helps!
Offline Sawyer
  • Software: v_7.020
« Reply #2 on: May 31, 2018, 07:37:21 AM »
Thanks for getting me to read closer FishSeeker,
I have all of CamoHunter's tutorials on my phone, he is a big help! I reviewed the Upload tutorial and found that "right click in the center" is adequate to load "all" of the newly added tracks, DAT, or Sonar (SON) files. I will have to go to my uncharted, north end of the lake and do a track, import the track, right click in the "center" of the map, and then see if the new chart data is added.
I hope this may help someone else also.
Offline Beaulieu80
  • Unit(s): 798CXI HD SI COMBO
  • Software: 7.68
« Reply #3 on: July 13, 2018, 09:51:31 PM »
AutoChart should merge all of them and store them inside a main file so we can more easily manipulate them. We need more merging options... I have over 100K of tracs points and I have created a software to management them into a single GPX file. so now I have one big g reen box to work with
Offline Sawyer
  • Software: v_7.020
« Reply #4 on: July 13, 2018, 11:45:05 PM »
Sounds like you were able to do what Humminbird couldn't. Good job!
Last post July 12, 2010, 01:44:17 PM
by kek1965
Last post February 07, 2011, 08:58:33 AM
Last post April 30, 2011, 10:57:34 AM
by Sodaksam
Last post September 19, 2011, 09:02:31 PM
by lcookie
Last post May 27, 2014, 01:51:52 PM
Last post July 08, 2014, 07:46:02 PM
Last post April 08, 2015, 05:19:25 PM
by gimez
Last post February 21, 2017, 06:32:23 PM
