Author Topic: Dedicated battery for units  (Read 9453 times)
Offline inshorecatch
« on: March 18, 2018, 11:10:47 AM »
Does anyone have 1 dedicated battery for there units. I am running a helix 9 and a onix 10 and am thinking of moving them of my house/crank batteries to its own. How do you have your battery chargers hooked up. Thanks for any insight.
Born Southern Fish by the Grace of God
Offline fshndude
Re: Dedicated battery for units
« Reply #1 on: March 18, 2018, 07:40:34 PM »
Two for the T/M, one for the boat and electronics. I am running two HB units a Helix G2N MEGA SI on the bow, a 899 si on the console all the time. Have not had a problem yet. Batteries are Delco voyager. I also have a Min Kota on-board charger that I plug in as soon as I get the boat home and it stays plugged in.
Dave in Currituck,NC
« Reply #2 on: March 18, 2018, 08:41:06 PM »
2 batteries for TM  ... Connected to a 2 bank XPS on board charger  ...
1 battery for starting  ... Shares 2nd 2 bank XPS on board charger with electronics battery  ...
1 battery for electronics  ... Shares 2nd 2 bank XPS on board charger with starting battery  ...
There are reported scenarios where RFI interference can back-feed from the TM - thru a common on board charger - and into electronics  ...
Plus 2 separate on board chargers allows having charging capabilities (with some wire swapping) if 1 charger dies and needs replacing  ...
Offline fishreed
  • fishreed
  • Software: current
« Reply #3 on: March 31, 2018, 04:04:36 PM »
I run 3 batteries in my boat with a 3 bank Cabelas  battery charging unit...1 group 31 battery for my engine crank battery,  another  group 31 battery for all the other boat stuff/ bilge/ 12 volt trolling motor  and live well pumps etc, and the 3rd group 27 battery for my sonar electronics. I troll with a 4 stroke kicker engine. You never want your live well pump running off the engine crank battery because you will get a big dead battery  surprise when you run the live-well pump all day and find your crank battery is dead.  I have a PERKO battery switch so if for some reason  I do run down the main  engine crank battery I can switch to  the 2nd battery as a crank battery.  I rarely fish for more than 8 hours a day as I have never even come close to running these batteries down because I have a 5 bank switchable console mounted battery check meter I can check charge status of any of the 3 batteries at any time.  Some guys run 4 batteries if they have a 24 volt trolling  motor. When I quit fishing I just plug in the 3 bank  charger and  it does its thing for all 3 batteries at a computer controlled  20 amps   with a maintainer  trickle charge.  Nice unit too, best $159.00 I ever spent as I'm ready to go the next morning.
« Last Edit: March 31, 2018, 04:15:27 PM by fishreed »
« Reply #4 on: April 02, 2018, 08:22:54 AM »
Nice do you have any pics of your set up?
Offline fishreed
  • fishreed
  • Software: current
« Reply #5 on: April 02, 2018, 08:56:07 AM »
Boat is in pole barn and the pics won't tell you anymore than what I have told you already...it's a pretty simple wiring set up. Maybe Rickie has pics of his set up as it is the same as mine except he has a 2-12 volt batteries for his 24 volt trolling motor batteries and a 2 bank charger.
« Last Edit: April 02, 2018, 08:59:45 AM by fishreed »
Last post January 16, 2012, 01:54:22 PM
Last post August 21, 2013, 03:14:38 PM
Last post January 28, 2014, 08:45:29 PM
Last post July 09, 2014, 06:46:29 PM
by LocDown
Last post December 31, 2014, 09:31:06 AM
Last post February 14, 2015, 12:21:31 PM
by BrokeLoser
Last post February 27, 2015, 03:53:25 PM
Last post November 07, 2015, 09:17:06 AM
by N9Phil
