Author Topic: Helix 5 DI/GPS Transducers  (Read 8181 times)
Offline moelkhuntr
  • Unit(s): 597 ci hd di, Helix 10 Chirp Mega SI
« on: August 04, 2017, 10:19:11 AM »
I currently use a Helix 5 DI/GPS on front of my Blazer SS. I am using the supplied XNT 9 DI T transducer on the trolling motor with a shield on it. Would there be any advantage SWITCHING  to the XTM DI 25 T. I'm thinking they both have the same coverage and I am not having any interference issues.
Re: Helix 5 DI/GPS Transducers
« Reply #1 on: August 05, 2017, 02:00:20 AM »
The piezoes are the same in both  ...the housing is different  ...
The XTM 9 DI 25 T has extra shielding for possible interference issues  ...
Over time, as your TM brushes wear = this can eventually cause interference  ...
HB offers a xducer exchange program when the xducer is still new  ... Yours being used now would just incur cost of buying the XTM 9 DI 25 T for a future interference issue that may or may not ever occur  ...
There is advantage in upgrading to the XTM 9 WIDE DI 20 T as this puck style xducer has 83kHz/60° and 200kHz/20° 2d beams (and extra shielding)  ...
Check your "Connected Transducer" Menu under the Sonar tab for a "HB + 83/200" selection to see if your unit will support the XTM 9 WIDE DI 20 T  ...
« Last Edit: August 05, 2017, 02:05:36 AM by rnvinc »
Last post July 18, 2015, 09:21:43 PM
by shanemcg83
Last post January 11, 2016, 09:02:24 AM
Last post March 20, 2016, 02:03:33 PM
by fishreed
Last post October 08, 2016, 10:09:16 PM
by Rpadar
Last post September 03, 2016, 09:35:03 PM
by Sewerdude
Last post June 07, 2017, 11:25:19 PM
Last post January 16, 2022, 12:38:53 PM
by fishingottawa
Last post November 27, 2023, 04:20:42 AM
by John Coward
