Author Topic: bad Interference from other electronics.  (Read 8489 times)
Offline Juicegoose
  • Unit(s): Helix 10
  • Software: N/A
  • Accessories: Minn Kota Riptide
« on: July 31, 2017, 08:51:27 AM »
I was gunna call humminbird this morning to discuss the issue as well but I'm getting wicked interference on my helix 10 whenever i run the trolling motor or even when a livewell pump comes on. you can see it like morse code on the side imaging screen and it gets worse as the trolling motor gets faster. Obviously its something in the negative wiring but I was curious how others have wired in their units to isolate them out. Thanks
Offline Rickard
Re: bad Interference from other electronics.
« Reply #1 on: August 01, 2017, 02:28:45 AM »
Hi,
Most people use a separate battery for the sounder. That battery doesn't need to be large. A 12V, 6 -10 Ah acid-lead battery lasts for a day on water.
Rickard
Offline MM7966756
  • Unit(s): H8 Mega DI GPS G3N; H7/SI/G2N
  • Software: Version 2.180
« Reply #2 on: August 12, 2017, 11:22:46 AM »
For what  it's worth, when I had that problem one of the guru's suggested I run a ground wire from the sounders negative battery terminal to the main engine. For me that solved the problem.
Last post April 15, 2009, 10:01:32 PM
Last post March 06, 2010, 08:28:51 PM
Last post June 17, 2010, 02:36:36 PM
by RzorbackAngler
Last post March 23, 2011, 06:13:39 PM
by stillbear
Last post March 14, 2012, 11:15:55 PM
by nhealy
Last post January 10, 2013, 05:38:13 PM
Last post February 24, 2014, 07:46:07 PM
Last post November 07, 2020, 12:39:32 PM
by Teddychk
