Author Topic: program only mapping a portion of recorded data  (Read 12447 times)
Offline johnmr12
  • Unit(s): 898c
« on: June 27, 2017, 10:45:42 AM »
i have been using the autochart software for about two years with no problems and now all of a sudden i'm having an issue. when i import the recorded data into the program and hit "map data", it shows all of the data i recorded for the day but when i click on "create map", it only maps a portion of the recorded data and the majority is gone. i assume since the data is showing when i hit "map data", that means the 898 unit is working fine. i haven't changed any settings or anything. any ideas?
Re: program only mapping a portion of recorded data
« Reply #1 on: June 27, 2017, 06:29:50 PM »
Are you sure you don't have some bad data ..... are you getting any problems with erratic depth readings?
Offline johnmr12
  • Unit(s): 898c
« Reply #2 on: June 27, 2017, 08:41:15 PM »
It happens whether I'm on plane or on the trolling motor. The data shows up on the SD card until I click on create map, then it loses a bunch of it. I am going to try and attach the screenshot showing the path my boat took today. This is what it looks like in the autochart program when I click "import.  You can see that the entire trail that my boat took today is on the card. I don't know how to post two screen shots together so I will post again what it looks like after I click "create map".
Offline johnmr12
  • Unit(s): 898c
« Reply #3 on: June 27, 2017, 08:43:06 PM »
The first picture that I posted is actually the data that is left after I click "create map". This is what it looks like when I import the raw data into the program. This is the complete path that I took on the water today.
Last post June 24, 2009, 07:29:53 PM
by Sundancer
Last post January 24, 2010, 09:00:52 AM
Last post September 18, 2012, 02:03:48 AM
by loeti
Last post April 21, 2013, 07:02:46 PM
by matt@reefmaster
Last post May 09, 2013, 11:54:43 AM
by Yrral3215
Last post March 18, 2018, 03:07:27 AM
by iceperch
Last post October 27, 2018, 03:07:25 AM
by NickBOE
Last post April 22, 2019, 10:55:52 PM
