Author Topic: smart strike  (Read 8994 times)
Offline Chris62
  • Unit(s): Helix 10Msi 3Gn
  • Software: 1.850
  • Accessories: Terrova 80 iPilot/Link V2.150
smart strike
« on: June 17, 2017, 05:55:42 PM »
I see that chart select allows one to purchase individual smart strike maps.
Will these work with any previous version smart strike card?
I would be using it in gen 1 helix 9si.
thanks for your reply.
Chris
Re: smart strike
« Reply #1 on: June 18, 2017, 09:01:05 AM »
Chris
I'm not sure of your question meaning  ...
SmartStrike (in this instance) is an additional feature that can be bundled with a Chart Select purchase on some specific lakes  ...
https://www.humminbird.com/Category/Technology/ChartSelect/
The Chart Select purchased "bundle" (including the SmartStrike feature if purchased in the bundle) is downloaded to an encrypted SD card  ... which becomes an active LakeMaster mapping card (with only the one lake on the SD card)  ...
If the SmartStrike feature was added to the purchased Chart Select bundle then that specific encrypted SD card (which is now a LakeMaster mapping card) will have the SmartStrike features available in the HB unit when that specific card is used in the unit  ...
A Chart Select purchased LakeMaster mapping card cannot be used at the same time as any other mapping card  ... The unit can only use one at a time  ...
I'm not sure if this answers your question  ...
« Last Edit: June 18, 2017, 09:05:55 AM by rnvinc »
Offline Chris62
  • Software: 1.850
Re: smart strike
« Reply #2 on: June 18, 2017, 09:24:15 AM »
Ok,
My question deals with the different versions of smartstrike 1,2 or 3 for Wisconsin.
Will the latest HD maps from chartselect work with all the above versions?
thanks,
Chris
Re: smart strike
« Reply #3 on: June 19, 2017, 11:43:00 PM »
Ok,
thanks,
Chris
Now that I do not know  ...
HB should be able to answer that for you  ...
1-800-633-1468
Last post March 28, 2012, 11:23:51 PM
by Gattlin
Last post January 20, 2014, 07:11:02 AM
by flatcat_auz
Last post December 31, 2014, 10:17:26 AM
Last post October 11, 2015, 08:02:45 AM
Last post October 02, 2016, 12:20:25 AM
by bass monkey
