Author Topic: Transducer XHS 9 HDSI 180 TU  (Read 12629 times)
Offline navionic
« on: April 25, 2017, 06:49:08 AM »
Please Help!
This transducer  has a frequency of 800 kHz ?
Support can not give a clear answer. Pin contacts like a XNT 9 SI 180 T
Offline Rüdiger
Re: Transducer XHS 9 HDSI 180 TU
« Reply #1 on: April 25, 2017, 08:39:14 AM »
Hi Navionic
Look here if the yellow label is correct http://www.humminbird.com/Products/XHS-9-HDSI-180-T/
mvh
Rüdiger
Finding is better than losing
« Reply #2 on: April 26, 2017, 12:55:46 AM »
The "U" in XHS 9 HDSI 180 T U is irrelevant  ...
Rudiger gives the correct link for the XHS 9 HDSI 180 T  ...
And it does utilize 455kHz/800kHz SI and 200kHz/83kHz 2d and temperature  ...
Offline navionic
« Reply #3 on: April 26, 2017, 05:20:37 AM »
Thanks , Rudiger and Rickie
Please post photo pin contacts your transduser  XHS 9 HDSI 180 T
« Reply #4 on: April 30, 2017, 10:17:16 PM »
Offline navionic
« Reply #5 on: May 01, 2017, 10:27:47 AM »
I'm aware of this scheme. Searching for real  photos
« Reply #6 on: May 01, 2017, 12:04:07 PM »
It's the same pin layout (as depicted in the diagram I posted above) for all core series SI xducers... and any core series cable compatible with the SI units  ...
« Last Edit: May 01, 2017, 12:08:04 PM by rnvinc »
Offline navionic
« Reply #7 on: May 01, 2017, 01:39:09 PM »
Thanks.
This XNT 9 SI 180 T or XHS 9 HDSI 180 T?
« Reply #8 on: May 02, 2017, 08:49:50 AM »
Thanks.
The pic is XHS 9 HDSI 180 T  ...
All HB SI xducers (except ONIX and ION) have identical pinouts...
The wire channels are the same for XNT 9 SI 180 T and XHS 9 HDSI 180 T  ...
Only the sounder SI transmitter is different in each head unit (and the rectangular bar piezoes are longer in the XHS 9 HDSI 180 T) ...
It is even possible to transmit 800kHz thru the XNT 9 SI 180 T  ... It just won't give very good results at 800kHz  ...
« Last Edit: May 02, 2017, 08:56:13 AM by rnvinc »
Last post March 26, 2010, 08:32:36 AM
by Jolly Roger
Last post April 27, 2011, 02:15:58 AM
by Roddy
Last post December 07, 2012, 07:52:12 PM
by reddog
Last post January 09, 2013, 02:46:33 PM
Last post October 18, 2013, 07:20:43 PM
by Kokanee
Last post February 25, 2014, 12:13:35 PM
by silvercloud
Last post September 01, 2016, 02:19:45 PM
Last post May 07, 2022, 08:12:06 AM
by Swann
