Author Topic: Autochart on Allegheny River  (Read 9900 times)
Offline drawde
  • Unit(s): Matrix 47,998 SI
« on: March 11, 2017, 05:16:18 PM »
Does anyone know if Autochart would work on the Allegheny River in Pittsburgh, PA.?  I don't want to buy a new Hummingbird if I can not chart the river.
Thank You for any replies.
Re: Autochart on Allegheny River
« Reply #1 on: March 11, 2017, 09:10:35 PM »
AutoChart products create map data from depth data ...
It should work in any waterway if the installation allows depth readings ...
Offline drawde
« Reply #2 on: March 13, 2017, 08:57:42 PM »
Thank You for the reply.  I was wondering if I could download the map into a SD card or would I need a special card?
« Reply #3 on: March 13, 2017, 10:32:53 PM »
A zero lines card comes with the Autochart PC software and that is where the map will be sent once it is created.  I'd recommend going with Autochart Pro.  There's a good deal on it over here    https://www.universalmania.com/products/humminbird-autochart-pro-dvd-pc-mapping-software-with-zero-lines-map-card
The Pro software will allow creation of SI mosaic maps, bottom hardness, and vegetation maps that the non-pro software doesn't support.
You will want to use a regular SD card to record to with your 998 and then bring that data into the software.
I strongly recommend getting the Lake images tutorial for Autochart.  It will save a LOT of time getting up to speed and is inexpensive.
The 3 disc set is a really good deal.... and they are a sponsor of this board.   http://www.lakeimagestraining.com/
Offline drawde
« Reply #4 on: March 14, 2017, 12:24:17 AM »
Thank You for the reply.  Learned much on the BBC Board.
Last post April 23, 2010, 11:57:30 AM
by mcguire2093
Last post May 14, 2010, 08:46:25 PM
Last post November 30, 2011, 04:46:10 PM
by DiveExplorer
Last post April 21, 2012, 02:30:48 PM
by shwfishing
Last post May 31, 2012, 01:10:34 PM
by MonteSS
Last post September 06, 2013, 09:51:47 AM
Last post March 06, 2016, 08:19:17 PM
by drawde
Last post March 24, 2022, 01:16:59 PM
by tournevase
