Author Topic: Linking 3 units  (Read 15748 times)
Offline 362 ranger pilot
  • Unit(s): 899ci hd/ 859ci HD
  • Software: 7.260/ 7.260
  • Accessories: Networked
Linking 3 units
« on: February 19, 2017, 06:19:56 PM »
I have a 899 and 859 link together via eithernet  now. I am wanting to add a 3rd unit mainly for gps navigation  at the console so I can have 2 full screens instead of running split screen on 1 unit.  So I would be able to see more detail on each unit.
My thoughts where to add another 859  head unit and run it off  the 899  transducer via eithernet.
can I link all 3 units together this way? for saving my way points? What would be needed to do this?
Re: Linking 3 units
« Reply #1 on: February 19, 2017, 10:28:36 PM »
You will need a 5 port Ethernet switch .... and will connect all units to it.   http://www.humminbird.com/Products/AS-ETH-5PXG/
Best way to back up waypoint is to export nav data to a 35Gb or less SD card and bring them into Humminbird PC
« Last Edit: February 19, 2017, 10:30:10 PM by Bob B »
Re: Linking 3 units
« Reply #2 on: February 19, 2017, 11:20:57 PM »
Thanks for the reply
I back everything up on ad cards
I'm just looking at other options on  seeing my god and mapping while also seeing sonar  while running
Offline gaj
  • Unit(s): 898 c si,858c
Re: Linking 3 units
« Reply #3 on: September 10, 2017, 04:32:43 PM »
I have two 899 SI units that I would like to link together. Not sure what additional cables I need to accomplish this
Re: Linking 3 units
« Reply #4 on: September 10, 2017, 09:51:45 PM »
For connecting two single xx9 series units you will need an AS EC QDE adapter for each unit (2 total)  ...
https://www.humminbird.com/productDetail-Accessory.aspx?Pageid=728&id=868
(Note: the AS EC QDE cables are ~ 1ft long)  ...
And you will need an Ethernet cable (1 total) long enough to reach  ...
https://www.humminbird.com/productCategory.aspx?id=3774&facets=7319,
Last post April 30, 2010, 11:25:10 AM
Last post April 15, 2013, 04:13:59 PM
Last post June 18, 2013, 01:20:39 PM
Last post March 30, 2015, 09:17:31 AM
Last post July 30, 2015, 11:22:29 AM
by tjstalb
Last post March 28, 2016, 10:48:08 PM
Last post May 08, 2016, 12:29:48 AM
by Rpadar
Last post October 09, 2023, 07:07:55 PM
