Author Topic: AutoChart Live: Is anyone actually using it?  (Read 13422 times)
Offline mako9man2
  • Unit(s): 999ci HD SI
« on: January 27, 2017, 10:21:04 AM »
Just curious if anyone is using AutoChart Live on the Helix?
If so what are you using to edit these files since AutoChart Pro won't accept the ACU files in their current format?
Offline October1
  • Unit(s): Getting ready to buy
  • Software: N/A
  • Accessories: None
Re: AutoChart Live: Is anyone actually using it?
« Reply #1 on: January 28, 2017, 08:15:43 AM »
I am very interested in hearing about this too. In regards to the Helix I had been told by HB that I needed AutoChart Pro to do side Imaging Mosaic.
Offline mako9man2
« Reply #2 on: January 28, 2017, 10:35:27 AM »
HB is correct about needing AutoChart Pro to do Si Mosaics.  I have the Helix12si gen1 and AutoChart pro.  I have been running the AutoChart Live option on my Helix as well as regular Sonar recording.  I can see the AutoChart Live running on the screen and the files are stored in Memory on the Helix (unless I have my Zline card installed in which case all AutoChart Live files transfer to the ZLine card).
When I try and upload the AutoChart Live .ACU files into AutoChart Pro for editing they won't load.  I get an error message about an incorrect format.  HB technical support so far has not solved my problem.
Honestly it is more of an inconvenience/aggravation than anything else since the regular Sonar recording  .dat files contains exactly the same information PLUS the SI data files.  AutoChart Pro accepts these .dat files so I edit them and build my maps including SI Mosaics if I choose.
I believe HB will work out the AutoChart Live upload issue otherwise why even offer AutoChart Live as an option on the Helix if you can't actually use the feature.
Incidently you can usually pick up a new copy of AutoChart Pro on Ebay for around $175 including shipping.
by CamoHunter
Last post January 31, 2016, 03:30:28 PM
Last post February 01, 2016, 06:00:30 PM
Last post September 13, 2016, 09:30:41 AM
by dutchguy
Last post May 29, 2017, 09:57:49 PM
by Mark Saikaley
by danceswithbass
Last post April 18, 2020, 10:02:41 PM
Last post April 28, 2020, 03:59:22 PM
