Author Topic: 998c si primary unit ethernet to a 959c HD  (Read 10408 times)
Offline 6speedy3
  • Unit(s): 788ci;998si
« on: January 15, 2017, 02:18:04 PM »
If I ethernet the 998 as the unit with the (side imaging ducer) to the 959cHD unit, will I get side imaging on the 959 from the 998? The chart on Humminbird's website is confusing.
I have the 998 ethernet with iPilot link and it has the latest software. I found a new in the box 959cHD online, so I know I will need to update the software on it.
Thanks in advance
« Last Edit: January 15, 2017, 04:58:01 PM by 6speedy3 »
Re: 998c si primary unit ethernet to a 969c HD
« Reply #1 on: January 15, 2017, 04:48:16 PM »
Sharing is came with software updates to the 98 series ..... You should be able to do this.
If the sharing was from a 999 to a 958..... I don't think it would work.
Offline 6speedy3
« Reply #2 on: January 15, 2017, 04:57:30 PM »
oops it is a 959ciHD.
Re: 998c si primary unit ethernet to a 959c HD
« Reply #3 on: January 15, 2017, 06:18:53 PM »
Should be OK .... The 959 should share the SI from the 998 .... just make sure all are at the latest software.
« Reply #4 on: January 15, 2017, 08:27:59 PM »
Here is the latest sharing Chart ...
http://www.humminbird.com/WorkArea/DownloadAsset.aspx?id=10463
Last post March 02, 2010, 09:55:50 AM
Last post May 26, 2010, 10:58:10 AM
by mlakrid
Last post February 24, 2012, 03:26:53 PM
by Enufzed
Last post February 19, 2013, 11:26:51 AM
Last post December 28, 2013, 09:28:07 PM
Last post March 04, 2014, 03:49:45 PM
by ConnorMN
Last post January 28, 2016, 10:04:53 PM
Last post October 24, 2017, 02:32:06 PM
