Author Topic: Helix 9 SI -- XI 9 20 Ice transducer  (Read 12581 times)
Offline jgardner2033
  • Unit(s): Helix 9 SI GPS
  • Software: 1.350
« on: January 08, 2017, 12:05:51 AM »
Hey guys, I just bought an ice transducer for my Helix 9 SI, It says clearly on the HB website that the XI 9 20 model is compatible with side imaging units including the Helix 9, it just says that you need to select quad beam as your transducer or dual beam for units without quad beam. Neither of these are an option when i go to select my transducer.
Nonetheless I can get the 2D sonar to work with the vertical flasher, however I would really like to have the round flasher available in Ice Mode on all of the non side imaging units. Does anybody know if this is possible or how to do so?
Anything helps, thank you in advance!
Re: Helix 9 SI -- XI 9 20 Ice transducer
« Reply #1 on: January 09, 2017, 09:13:39 AM »
Directly from the HB FAQ ...
http://www.humminbird.com/Category/Support/FAQ/SI_Ice/
Did you cursor left and right in the "Connected Transducer" "Menu" to see all the available choices ...??
Offline October1
  • Unit(s): Getting ready to buy
  • Software: N/A
  • Accessories: None
« Reply #2 on: January 26, 2017, 04:10:52 AM »
I was told by HB that flasher mode is only available on the Helix 5 & 7 and even if they have side imaging despite what their Q&A section says. I'm curious what you found out.
Last post February 28, 2015, 06:51:54 AM
by mako101
Last post January 10, 2016, 09:15:53 PM
by leonardk
Last post February 15, 2016, 10:01:01 PM
Last post March 07, 2016, 11:14:58 AM
Last post April 04, 2016, 10:15:28 PM
Last post April 29, 2016, 08:25:08 AM
by Kicker2905
Last post June 02, 2023, 09:14:12 AM
by kpkyllo
