Author Topic: 899 SI powers up, then shuts down ??  (Read 16711 times)
Offline Time Out
  • Unit(s): 899 Ci Hd Si
« on: November 29, 2016, 03:18:29 PM »
HI guys,
Overnight about 14 hours total I left my ignition on with the boat key.  Saw it in the dark the next morning........Uggggg.
Day before all was good.   That day, the sounder came on, but then would power down and recycle but never gave the sounder.  The unit stay on.  Would say, "shutting down" and then just stay on main intro screen.
This I believe due to not enough output from batteries?  I charged and an am still having issue.  If I'm on the right track, wondering if the batteries are compromised and done?
What do you think?
Re: 899 SI powers up, then shuts down ??
« Reply #1 on: November 29, 2016, 08:17:59 PM »
Set one of the readouts on the units to display the voltage and see what you have ..... Should be over 12.4 or so with fully charged batteries and good wiring.
Offline Time Out
« Reply #2 on: November 30, 2016, 07:46:23 PM »
2 new batteries.  Same problem.  Huh?
Offline Time Out
« Reply #3 on: November 30, 2016, 07:47:30 PM »
About 12.8 with new batteries.  Actually charging them anyway.  Ran boat went to 13.4.  Same problem.
« Reply #4 on: November 30, 2016, 10:20:40 PM »
Sounds like something got corrupted ..... If it stays on long enough, try to reset defaults.   Corrupt waypoints can cause this kind of issue also.
Gonna be kind of hard to troubleshoot if it won't stay on.
Offline Time Out
« Reply #5 on: December 01, 2016, 07:14:45 AM »
Is there a reset default?  What buttons would I hold?  I have as long as I want on the screen that requires me to "exit" but all other screens maybe 3 mississippi and gone.  And resets to the exit screen after "shutting down" comes up.
Code: [Select]
I remember a Lowrance having this years ago.  All the wiring looked clean underneath so I wouldn't know where to start and I'm not real astute to that anyway.
Offline Time Out
« Reply #6 on: December 01, 2016, 07:22:34 PM »
Think I reset the machine. All "appears" good. Thank you sir.
« Reply #7 on: December 01, 2016, 08:56:52 PM »
There's a reset default setting in the setup menu .....good idea to do that before and after a software update also.
Glad you got it resolved.
Offline dbell
  • dbell
  • Unit(s): 899 ci HD SI, Helix 7 G2
  • Accessories: HD transducer
« Reply #8 on: February 14, 2017, 09:15:36 PM »
Time Out, How did you reset the unit? Did you actually reset it or just reset the factory defaults?
Last post June 08, 2009, 02:50:47 AM
Last post June 12, 2010, 06:40:39 PM
by stillbear
Last post June 30, 2011, 10:28:36 AM
by Kees Michielsen
Last post November 29, 2012, 11:42:40 AM
Last post April 09, 2013, 10:50:31 AM
Last post April 27, 2014, 05:31:31 PM
Last post February 09, 2015, 12:11:40 PM
by N9Phil
Last post January 09, 2016, 06:28:20 AM
by skeeter08
