Author Topic: Mega imaging from Humminbird is here ...  (Read 29055 times)
« Last Edit: November 15, 2016, 04:20:10 PM by rnvinc »
Re: Mega imaging from Humminbird is here ...
« Reply #1 on: November 15, 2016, 08:46:38 PM »
Mega Sample Images
« Last Edit: November 15, 2016, 08:52:28 PM by Bob B »
« Reply #2 on: November 15, 2016, 08:58:13 PM »
Lots of new stuff .... and still more to come....It's that time of year.
The Autochart Live in the G2 Helix models will also show bottom hardness and recognize and display weed areas.  Supposed to be able to follow a contour or a weed edge with the new I-pilot link ..... and spot lock is supposed to be MUCH improved.
http://www.minnkotamotors.com/Press-Releases/
« Reply #3 on: November 15, 2016, 09:34:48 PM »
A few more sample images.
Offline Nitro78
  • French frog
  • French frog!
  • Unit(s): Solix mega
  • Accessories: TM265 LH + 2 side imagin transdeucer an
« Reply #4 on: November 16, 2016, 11:45:34 AM »
Is there a possibility to have that on ONIX in futur?
Offline D S
  • Software: 7.5
« Reply #5 on: November 16, 2016, 01:29:04 PM »
any technical  info on this mega imaging from press release it looks as its still 455khz beam ??
is this just new Gen 2 units with repacked technology? or has there actually been an advance made to enhance images?
DS
stgr
« Reply #6 on: November 16, 2016, 01:30:36 PM »
The RUMOR is there is something major coming for the Onix also.
« Reply #7 on: November 16, 2016, 01:40:51 PM »
DS
The MEGA beam is 1200 Khz (1.2 Megahertz) that is why they are calling it mega.  The higher frequency gives higher resolution.
This image and other info is in the link Rickie refereced in the original post.
The Mega scan range is 125' both directions and the 455 now has an extended range of 400' each side.  The new units also have a new transducer to support the higher frequency and there is also now a dedicated DI element in the transducer for sharper DI.  The 2D, SI, and DI are all chirp.
« Last Edit: November 16, 2016, 01:42:24 PM by Bob B »
« Reply #9 on: November 16, 2016, 02:00:20 PM »
HELIX G2N SI models are showing new xducers ...
XM 14 T for HELIX 12 SI G2N ...
http://www.humminbird.com/Products/HELIX-12-CHIRP-MEGA-SI-GPS-G2N/
XM 9 20 MSI T for HELIX 10 SI G2N and HELIX 9 SI G2N ...
http://www.humminbird.com/Products/HELIX-10-CHIRP-MEGA-SI-GPS-G2N/
I can't find much specs yet ... except this ...
CHIRP/Side Imaging/Down Imaging/DualBeam PLUS
455kHz Side Imaging provides 800 ft of side to side coverage.
455kHz Down Imaging works to a depth of 400 feet.
1.2 MHz Side Imaging provides 250 feet of side to side coverage.
1.2 MHz Down Imaging works to a depth of 125 feet
All 3 sizes HELIX DI G2N still listing XNT 9 DI T ...
All 3 sizes HELIX Sonar G2N still listing XNT 9 20 T ...
« Reply #10 on: November 16, 2016, 02:02:26 PM »
And as Bob mentioned ... we do know these new xducers have what is called 2 Mega SI elements, 1 Mega DI element, Dual Beam, Temp in one xducer ...
The images posted clearly show CHIRP 1200kHz fixed frequency and CHIRP 1175kHz - 1275kHz sweep frequency ...
We will post new info as it becomes available ...
« Last Edit: November 16, 2016, 02:20:01 PM by rnvinc »
Offline mako101
  • Unit(s): 798si hd
  • Software: 5.210
« Reply #11 on: November 16, 2016, 07:27:34 PM »
Can Bluetooth be used with Navionics SonarChart Live on a mobile device?
« Reply #12 on: November 16, 2016, 07:44:31 PM »
From what I have read the initial Bluetooth functions are pretty basic.....displaying phone messages and an app that does some basic stuff as well as a Bluetooth  remote.
My suspicion is that Bluetooth function upgrades will be part of the update candy.
Offline abraquelebout
« Reply #13 on: November 17, 2016, 12:44:17 PM »
 :)verry, verry,  intersting has anny one know the price ??
« Reply #14 on: November 17, 2016, 02:30:15 PM »
BBG Marine posted this at another forum ...
Quote from: Brian@BBGmarine;3314248
Here is the MRP pricing on all of the MEGA Si units coming. I will work on getting transducer pics and all other details as we go.  Brian
$2499.99 MRP--HELIX 12 CHIRP MEGA SI GPS G2N
 $1699.99 MRP-HELIX 10 CHIRP MEGA SI GPS G2N
 $1299.99 MRP-HELIX 9 CHIRP MEGA SI GPS G2N
Offline Whistler
  • Software: 7.510,7.460,1.460
« Reply #15 on: November 18, 2016, 01:00:49 PM »
Holy cow!  That fish shadow is AWESOME!
Offline sonarbear
  • Unit(s): HB 898cxi SI HD
  • Software: na
  • Accessories: transom mount rod :-)
« Reply #16 on: November 22, 2016, 08:03:58 AM »
Must be a 3 m fish? I don't think the shadow looks like a fish because of actual shape of the animal but bacause of its movement during the scan. It's not a 2D image but a linescan.
In general, the images are nothing short of astounding. Whether they will really be of any practical use, I'm not so sure. Already the current units completely fill the monitor resolution. The biggest advantage is rather for looking at things back home. As far as fish are concerned, things might even be worse, since fish will be drawn smaller compared to conventional units, which paint a big bright blob for a fish. It's kind of obvious even in these images: at first glance, the bigger fish are missing. But when you look at the picture in detail, they are actually there, just really hard to see.
And in terms of actual resolution, it's not different from Garmin / Lowrance. Sure, the frequency is higher, but if the elements have the same length as current models, the increase in frequency only outweights the difference in length, yielding similar resolution. I think the Panoptix Multi-Beam approach is a much more fruitful road towards the future. Dynamic, 2D/3D, real-time, seem much more desirable to me in terms of fishing. In terms of pretty pictures though, Mega is awesome!
Last post March 21, 2017, 05:00:45 PM
Last post March 04, 2018, 02:15:08 AM
by iceperch
Last post September 16, 2018, 03:15:09 AM
by cade
Last post January 06, 2019, 02:05:37 PM
Last post June 19, 2019, 08:30:04 AM
by davidgronskei
Last post November 19, 2020, 06:50:16 AM
by danlaboucane
Last post March 07, 2021, 01:26:00 PM
by ezfishn
Last post May 23, 2023, 08:14:23 PM
