Author Topic: Best softwares to 859ci HD DI Combo and 596c HD DI  (Read 15464 times)
Offline Terppa
  • Unit(s): 596c HD DI, 859ci HD Combo
« on: August 11, 2016, 05:52:27 AM »
Hello and greetings from Finland!!
I am sorry for the bad english but hopefully members understand what I want to know.
I use those sonars mentioned in the topics tittle. I do not have any problems with them, but I would like to know the best software or firmware to both sonars. Like I mentioned, they work superb. So I don't have a serious need to update.
I do not have any equipment's (cannonlink etc) attached to sonar (yet :D). So no need to update due to possible problems with them.
I use the search but I did not find any topics. Can someone link if there is one?
Thanks in advance and happy fishing with sonars!!
And please ask if there is something you can't understand in my message.
Re: Best softwares to 859ci HD DI Combo and 596c HD DI
« Reply #1 on: August 11, 2016, 11:50:15 AM »
What software versions do you have now?
Offline Terppa
« Reply #2 on: August 11, 2016, 01:24:00 PM »
Hello Bob B. 596 has a version 5.250
859 version I will check tomorrow.
« Reply #3 on: August 11, 2016, 01:43:15 PM »
I don't know if those models have 6.49 software or not, but in my opinion, that is the best release if you don't have an accessory like the 360 that requires a higher release.  If 6.49 is not an option, it would be the highest release number that is lower than 6.49...if that makes sense.
The possible exception to that would be if you ever want to install the cannonlink.....I'm pretty sure Humminbird dropped support for that, but I don't know what the highest release that supports it....Maybe Rickie or someone else will check in that know the answer to that ....Otherwise you might want to call customer service and ask them that question.
Offline Terppa
« Reply #4 on: August 12, 2016, 02:51:36 AM »
Thanks again.
I will check that and if necessary I will be on contact to Humminbird.
859 software is 6.820
And I do not have any accessories.
« Reply #5 on: August 12, 2016, 10:45:38 AM »
It is not recommended to load an older version of software than what came on the unit ...
This means your 859 may not be conducive to try the 6.490 version ...
The 859 (Sonar or DI) did not receive the ping sequence change like the SI units did for the 360 release...so the newest version in your HB account would most likely be fine ...
The 596 would most likely also be fine with the newest version available in your HB account ...
« Last Edit: August 12, 2016, 10:46:54 AM by rnvinc »
Offline Terppa
« Reply #6 on: August 12, 2016, 10:55:40 AM »
Thanks Rickie, I will update later in the autumn when season is almost over. Now I enjoy fishing and well working HB products.
Offline Boots
  • Unit(s): 998,788, purchasing twin 1199's
  • Software: NA
  • Accessories: Thru Hull trans??
« Reply #7 on: August 12, 2016, 08:00:56 PM »
Run the newest available for that unit. They do there best to fix the minor bugs. It's about fool proof.
Last post April 03, 2009, 03:00:40 AM
Last post March 07, 2013, 04:43:29 PM
by RivRunR
Last post February 01, 2014, 01:23:18 PM
by jjbch
Last post February 03, 2014, 12:47:28 PM
Last post February 07, 2014, 02:36:26 PM
by Shane23ss
Last post August 04, 2014, 06:35:22 PM
by klqnguyen
Last post June 04, 2014, 11:01:14 AM
Last post November 06, 2014, 10:34:01 PM
