Author Topic: downloading waypoints from one unit to another  (Read 7706 times)
Offline graggy
  • Unit(s): 898C si
« on: July 22, 2016, 06:19:59 AM »
I have an 1199 on my boat and just put two new 999's on another boat. Can I put my waypoints that are on my 1199 onto these other units without entering them one at a time? If so can someone walk me through how to do it? Thanks
Re: downloading waypoints from one unit to another
« Reply #1 on: July 22, 2016, 12:17:15 PM »
*Insert SD Card into either slot ...
*Press "Menu" twice to get into the Main Menu System ...
*Cursor over to the Nav tab ...
*Cursor down to Waypoints Routes Tracks ...
*Cursor right to open Waypoint Management ...
*Cursor to highlight "Options" ...
*Cursor right to open Options menu ...
*Cursor to "Select All and..."
*Cursor right to "Export" ...
*Cursor right to command the export ...
*Confirm the green popup ...
You should get a white popup confirming the export to SD Card ...
Remove the SD Card and stick it in the other unit (with the unit already powered up) ...
You should get a green popup asking if you want to import the Nav data ...
Confirm ...and wait for "Import Successful" white popup ...
Last post April 05, 2010, 07:11:06 PM
by easysailor
Last post August 27, 2012, 04:11:04 PM
Last post January 11, 2013, 11:10:23 AM
Last post February 28, 2014, 09:58:43 AM
Last post April 25, 2014, 03:40:47 AM
by slabbacks
Last post September 17, 2014, 10:33:09 AM
Last post April 16, 2015, 10:46:13 AM
by graggy
Last post April 07, 2019, 11:23:12 AM
by ezfishn
