Author Topic: Having Two SI Transducers Side by Side?  (Read 12224 times)
Offline snooktarpon
  • Unit(s): 1199ci HD SI, 899ci HD SI
  • Accessories: AS-ETH-5PXG
« on: June 22, 2016, 08:10:34 PM »
Can I have two SI transducers mounted side by side? If yes, should they be X distance apart?
Offline Gimp
  • Unit(s): 998 HD SI
  • Accessories: i-Pilot Link
Re: Having Two SI Transducers Side by Side?
« Reply #1 on: June 22, 2016, 08:23:36 PM »
You need to clarify a little bit. Are you going to use the two separate ducers on two separate units at the same time. If so, are the two separate units the same make and/or model?
Offline snooktarpon
« Reply #2 on: June 22, 2016, 08:33:52 PM »
Two separate transducers. One is for a 598c HD SI and the other is for a 1199ci HD SI. I currently have the 1199 transducers mounted to trolling motor at the bow and the 598 transducer is mounted on the transom. I have a small mounting plate on the transom that can accommodate two transducers but they would be about 1 inch apart from each other.
« Reply #3 on: June 22, 2016, 10:45:05 PM »
The near side SI beam on each xducer will be blocked mounting 2 SI xducers at the same height ...
This is because the SI beam reaches all the way to water's surface on each side ...
There will also be crosstalk interference running 2 HB xducers at the same time because the 200kHz 2d beam cannot be shut off without completely shutting off the Sonar transmitters ...
« Last Edit: June 22, 2016, 10:47:16 PM by rnvinc »
Offline snooktarpon
« Reply #4 on: June 24, 2016, 11:52:54 PM »
Thanks for the reply. Based on your response, I'll keep the 1199 transducer at the bow and the 598 transducer at the stern.
Last post July 23, 2010, 05:18:21 PM
Last post October 17, 2012, 01:37:25 PM
Last post June 21, 2016, 11:33:31 AM
Last post January 19, 2017, 11:13:58 PM
