Author Topic: Display ContourXD map with Autochart overlay  (Read 8247 times)
Offline Riverseeker
  • Unit(s): Helix 9 SI GPS KVD
  • Software: 1.210
« on: June 19, 2016, 11:08:50 AM »
Helix 9 SI
How can I display the ContourXD map and the Autochart data (either live or saved data) at the same time?
« Last Edit: June 19, 2016, 12:43:00 PM by Riverseeker »
Offline LGF
  • Luke, I don't have hobbies just Obsessions!
  • Unit(s): Helix 7 SI GPS HELIX 9 CHIRP MEGA SI G2N
Re: Display ContourXD map with Autochart overlay
« Reply #1 on: July 14, 2016, 02:06:26 PM »
Was wondering the same thing and as I'm new to using SI and the helix systems for that matter I am also keen to know how this can be done?
When I die, will someone please dress as the Grim Reaper and attend silently and a little distance away from the rest of the crowd? ROFL
Offline Riverseeker
  • Software: 1.210
« Reply #2 on: July 15, 2016, 11:50:18 AM »
If you set the base map as ContourHD and turn on display live data in autochart, it will overlay your recordings on the base map. Apparently once you convert the data into the autochart map, it puts it in a format that is not compatible with the ContourHD format and they can not both be displayed at the same time. The ContourHD is in Navionics format and autochart uses Lakemasters format. I suspect if you had the Lakemaster base map you could then overlay the processed autochart maps...and maybe even see the autochart live data at the same time. Can anyone confirm or correct my assumptions?
« Last Edit: July 17, 2016, 09:33:28 AM by Riverseeker »
Last post October 13, 2009, 09:41:10 AM
Last post December 11, 2009, 11:38:06 AM
Last post August 26, 2010, 01:58:59 AM
by ElvisMarcy
Last post February 23, 2012, 07:24:10 PM
by LocDown
Last post March 11, 2014, 04:32:21 PM
Last post May 05, 2014, 12:21:15 PM
Last post October 26, 2014, 02:20:25 AM
Last post May 11, 2015, 11:49:07 PM
