Author Topic: Stripes in image  (Read 8392 times)
Offline sonarbear
  • Unit(s): HB 898cxi SI HD
  • Software: na
  • Accessories: transom mount rod :-)
Stripes in image
« on: May 05, 2016, 06:26:05 AM »
Hi,
yesterday I was having weird stripes in the 455 kHz SI. You cann see very thin horizontal lines, typically one ping, where there is very little, if any, return. Then there is also the wider dark area, where it seems that recording didn't capture anything. The 2D is also failing at this point.
What's happening? Bad contact in plug? Bubbles below xducer?ila_rendered
Re: Stripes in image
« Reply #1 on: May 05, 2016, 11:37:55 AM »
Dark horizontal lines in the SI image are usually blockage of some sort ...
Intermittent dark horizontal lines are usually bubbles ...
Advance the recording thru that area of the history and notice if your boat speed may have increased ...which can increase the likelihood of bubble creation from your hull design ...
Offline Rickard
« Reply #2 on: May 05, 2016, 01:20:10 PM »
Seaweed on the transducer may look like that. /Rickard
Last post August 30, 2011, 08:58:26 AM
Last post October 18, 2011, 02:40:34 PM
Last post March 22, 2012, 09:04:53 AM
Last post April 15, 2013, 01:03:52 PM
Last post February 12, 2014, 12:03:37 PM
Last post April 07, 2014, 02:46:21 PM
Last post August 20, 2015, 12:54:42 AM
Last post July 14, 2016, 11:33:51 PM
